yanmar 1500d front driveshaft
/ yanmar 1500d front driveshaft #1
stinson89
Kentucky
yanmar 1500D
I bought a yanmar 1500d and it is missing the front driveshaft. The guy i bought the tractor from claims that it got stolen. Everything seems to check out fine front end wise, but my question is has anyone ever made a homemade front driveshaft with some square tubing and some ends from tractor supply. Or would anyone happen to have a extra one or a old laying around they want to get rid of.
/ yanmar 1500d front driveshaft #2
Call Hoye. I bet he has several shafts.
I am sure you could make one out of square tube and some yokes.
There must be a common problem and reason for this. There is a 1500 in my area on CL right now that is missing the front shaft???
/ yanmar 1500d front driveshaft #4
I'm not sure you would find the right ends at tsc. They use metric ball bearings in the cups at each end. It's only held in with spring tension and a cotter pin. I think the easiest way i think is to buy the new shaft and parts. I think you risk damage to other parts by making one.
/ yanmar 1500d front driveshaft #5
oh yea i forgot about the ball bearing ends etc. i dont have a D model so i dont see one.
/ yanmar 1500d front driveshaft #6
;) I like to make as much as I can but I see that being more of a pain than it's worth. I did notice that the spring and washer that go with the install are not listed under the additional needed items.
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59914)
2019 CHEVROLET...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A65643)
2010 INTERNATIONAL...
