Hard Starting
/ Hard Starting #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Question for the masters. Why in the world would it take 20 pulls to start my 034 super AV. It has a new impulse line. Does the carb diaphragm get weak and not pump over time? Once started the saw will run perfectly all day and idle forever without a hiccup. cuts like mad after muff mod But just doesn't start worth a crap.. I have 4 other Stihl's and they start fairly well.,
/ Hard Starting
I bought what seems like a nice compression tester. I'm get 112# compression. I'm not sure if that is too low for a good start. The saw is not weak by any means. Cuts like mad. I have an 026 pro and the 034 seems to have more snort than the 026.
/ Hard Starting #4
I've owned two Stihl saws over the years and both required several pulls (8-12) to start after they sit idle for a few days. I figured it was just something they all did.
/ Hard Starting #5
I had a generator that would take forever to start after sitting for some time. I would blow some air in the fuel tank and it would fire right up.
Have you tried storing it in a different position? possibly not getting fuel right away.
Reason I mention this is because I have had 2 stroke dirt-bikes that I have always started easier when I would tip them to the side for about 5-10 seconds. This would prime the carb. and then it would start easier.
/ Hard Starting #6
My old Stihl needed a shot of starting fluid to get it going in the cold. Had to ALWAYS empty it of fuel, too. NEVER would start worth a **** if any fuel left in it. It didn't have the pump thingie to prime it.
Ralph
/ Hard Starting
Stihl has the pump primer bulbs on the weed eaters and pole saws. Why not on the chain saws?
/ Hard Starting #8
My MS 290 will start after sitting for several months with just 4 pulls. I treat the fuel with StaBil and clean the spark plug and air filter after about 15hrs of cutting.
Did the problem start after the muff mod? May not be getting enough backpressure due to the low rpm when pulling the chord.
/ Hard Starting #9
I ran my MS210 yesterday. Last time it ran was the end of September last year. 4 pulls to start, maybe 5 at the most. On any two cycle carb the fuel pump diaphragm can get stiff so it does not work as well as it should. I have not had that issue with the saw yet but a used Stihl hedge clipper did. New diaphragm fixed that hedge trimmer so it starts easily now.
I do use high test for all my gas engines. I hope high test has less alcohol.
/ Hard Starting
It has always started hard even before the muff mod. If it sits a week or so it takes 15 pulls. I cut a lot of wood and rotate the saws a little but the 034 is usually sitting at my cabin unused most of the time.. I mostly use a 039 or 044. They start right up. This little 034 hates me. Anyone want to buy it? lol..
/ Hard Starting #11
I've been using 2-cyle motors since the mid-1960's. I've come to believe that they're like children - all of them are different and some of them are extremely finicky.
I learn what it takes to get each motor started. The blower/vac takes 5 pumps of the primer bulb unless it's completely warm. The MS192 saw takes three pumps of the primer bulb (more and it floods, less and it's not enough), the choke set to full choke and two pulls - then the choke at 1/2 choke for one pull and it starts. The MS 261 after sitting for several weeks takes two pulls at full choke, then two at half choke - and it starts.
You see what I mean...none of them start the same way. I've found that my Stihl equipment absolutely hates gas with ethanol even if you put ethanol treatment in the gas and stabilizer.
I've switched to 100 octane unleaded with no ethanol. All of the equipment works better and starts easier.
Unless there is a mechanical problem (blocked passage, stiff diaphragm, leaky fuel line, etc.) - I would check the sparkplug and make sure it's either clean or new; change to ethanol-free 92+ octane unleaded fuel; learn the exact starting sequence that each tool seems to like.
/ Hard Starting #12
They do on the "Homeowner" and "Farm and Ranch" saws. The "Professional" saws do not have the primer bulb.
/ Hard Starting #13
Compression seems low to me. I am thinking off the top of my head it should be at least 160.
/ Hard Starting #14
You are Stuck with the hard starting as the diaphragm has gotten hard from ethanol. Should try to start on the first pull with choke full on. If it does not go to partial choke and it should fire and run. The either should be reserved for old Cat engines. When you have the carb apart to replace the diaphragm check the fuel hose also. Give the carb time to soak in cleaner. If you do this they will be ready to run if you dump the fuel when you are done.
/ Hard Starting #17
I would definitely use ethanol blocker/additive or find non ethanol fuel. Had similar problem with my saw this past year. I figured compression was too low after using for couple years. Started to use ethanol additive and saw has worked pretty good ever since. A repair shop told me to use premixed, only problem is its expensive and im cheap at times..
/ Hard Starting #18
I did fail to mention I use pure gas in all my equipment.
/ Hard Starting #19
I had an older saw that had a very similar problem, but being as it was 70 cc I usually ran out of juice before it would start.
Originally thought it was a fuel problem also. Checked compression at 100 lbs. thought that was good. Then I looked it up online and it was supost to be around 185 lbs.
The saw had a stuck ring,pulled the jug and remove ring and repaired ( with the file I sharpen the blade with). Re assembled it and got compression up to 165.
Starts like a new one. Second pull every time.
/ Hard Starting
Interesting. I did switch to non ethanol fuel a while back. I may as well throw a kit in the carb before I throw a new jug and rings at it. I'm shocked at how inexpensive the cylinder and piston kits are. Even complete engines are reasonable. I'll do another comp check 1st. Stihl says 160 is new.
Thanks.
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
