mikehaugen
Elite Member
Mythbusters has done this one at least twice. The only way to improve on stock is with a tight tailgate net if I remember. Same airflow stuff as tailgate up & a bit lighter.
Or a tonneau cover so I've heard.
Actually better with it up.
With it up the flow is more laminer. With it down the air churns just behind the cab creating induced drag.
The gain is minimal, about 3% if I remember correctly from the wind tunnel test we did 20 plus years ago.
Chris
The net actually made it worse. All other configurations were negligible gains.
Surprised dot didn't get them. Here they would have been all over him he wouldn't know what to do.
Ok, I will get all technical on you guys. The cab of a truck is working like the wing of a airplane.
The way a wing works is its basically flat on the bottom and curved on the top. Imagine a molecule of air hitting the leading edge and splitting in half then rejoining on the trailing edge. The half of the molecule on top of the wing has to travel farther so it must travel faster then the half going under the bottom. This creates a pocket of low pressure above the wing that literally "sucks" the wing up. This is how lift is created and how a airplane flies.
Same thing is happening with your trucks. Imagine the doghouse, cab, and bed as the wing. The low pressure being created on the top side is sucking things out of the bed.
Chris
You can see this if you have a little loose hay or woodchips in the bed of your truck and you drive down the road.
They will loop around in the back of the truck.
Aaron Z
My Bro sent this to me , found it somewere on the net . And " NO " this is not ME or My Trailer , ( I have a Big Tex Dump
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=413172"/>
Fred H.
Fred H.
Heck that was an easy tow.Picture was on this site .View attachment 413189
Fred H.
I'm within the allowable weight rating for the trailer, tires, hitch, and for the Subaru.
It was 20 miles on back farm roads, open country with no one else around, 40 mph max in a few spots that had a half mile line of sight, but mostly slower. It was uneventful.
Planning was about the same as you would do for a special-permit oversize load, ie travel at an hour when nobody is on the road and didn't get near populated areas.
This earlier one below was hairier. It was several hundred lbs lighter so less stress on the trailer but the weather was over 110 and the only route was down I-5, the sort of modern interstate with little traffic but with areas posted 70mph. 45~occasionally 50 mph on that route for a hundred miles was definitely hair raising.
In both those transports, I never got anywhere near another car so no excitement from anything unexpected. The main consideration was to think far ahead and leave so much space in front of me that I could have come to a complete standstill if something weird occurred way down the road ahead.
But none of my three tractors has ever left the ranch after arriving. No need, and no interest in repeating those tows.
Driving an HD setup does not make you immune to accidents.
Rgds, D.
It just means we lived through the idiotic things we did when we were young and now can afford bigger toys. Hopefully learned a few things along the way.
