hello all
/ hello all #1
highonlife510
williamsville
ford 3600
hi all
i'm looking to purchase a use new holland compact tractor with hydrostat and i've been looking at a tc45da online but i was wondering if someone could help me with a few things. first what is the differences between the 45, 45a, 45d and 45da? secondly do all the models have a seperate power steering pump bc i'm wanting to get a tractor with a loader and i've read that u want a ps pump seperate from the FEL. and third do the older model tc tractors at that size stack up to the newer "boomer" tractors bc i've also found a boomer 40 that seems to be nice...same price and hours as the 45da but obviously less hp, but newer. so i wondered why anyone would go with a 2010 boomer with the same amount of hours as a 2005 tc45da and sacrifice that extra 5hp just to have a newer machine. are the hydralics or hydrostat better? thanks
/ hello all #3
Not a NH guy, but'll throw in my 2 cents.
Every tractor I've looked at has dual pumps, one for steering, 1 for everything else, even if the literature doesn't say so up front.
According to TractorData.com, the 45D is the deluxe model, the 45 is the base, while the A in both indicates the later model numbers of the tc45. As the run was from 2003 to 2008, yours is the deluxe model made toward the 2008 side.
The overall hydraulic capacity is listed a 9.8, which is less than my new 35HP tractor, so I would guess the TC is an older model cut, which may make it less desirable than the boomer. The boomer has a hydraulic capacity of 13.7, which you will notice more than the 5HP difference.
To my mind, the 4gpm hydro flow difference is more important than the 5HP difference, which in all likelyhood you will never notice, unless you are maxing out the tractor with a mower or tiller, in which case you need a bigger tractor. As the boomer is probably better ergonomic wise, I would go with the boomer.
The boomers are still in production, so parts and service would be more readily available if the occasion arose.
In answer to your question, the hydraulics on the boomer are likely WAY better, another reason why I would go with it.
Remember, HP isn't the only thing to look at with a tractor, look at GPMs and Weight too, among many others.
/ hello all #4
Welcome to TBN!
Just an FYI, but the Boomer 40 was actually made by LS (they call it an R4041H)....the two are the same minus graphis, headlight bezels, and a significantly weaker loader on the Boomer. The kicker is depending on where you buy it, the LS will cost for $7-10K less than the Boomer. I had the higher hp version LS (R4047H) which was the same as a Boomer 50, and I paid $21,500 (with FEL) out the door in December of 2012...price went up $500 or so since then. They have stopped making that series, but there are a few still around. From what I've seen of used prices for the TC models, you could buy a new LS for the same money.
Also, the TC line was made by Shibaura for NH.....Case/NH doesn't make their own SCUT or CUT machines any longer. The negative (to me) for the TC is that it has an FEL with roughly 40% less capacity compared with many models of similar size (roughly 1,800lbs compared with 2,500lbs or more).
It likely boils down to condition if you're set on those two machines, and that's hard to tell without seeing them in person.
/ hello all
thank you guys...that helps a lot. i def will consider the LS tractors now...i was looking at them bc we have a local dealer that sells them but i didn't know that they were basically the same tractor. and as far as the hydraulics are concerned, i didn't even think about that being more important than the 5 extra hp. my step dad has a 45 hp kubota and i like it but i like the nh better bc of the curved hood that lets you see in front of the tractor much better and i think he replaced the starter a cpl years back and i think he said that the part itself was a few hundred bucks so i just thought that that was gonna be a problem with the kubota having parts be that expensive. but for all i know all the cut machines parts are gonna be high. and a kubota, to my knowledge the kubota's are in the same price range as a deere so i would go with a deere over the orange machine. the thing about the LS, Mahindra's and other similar tractor i wasn't sure about is them being the "cheap" little tractors and how well they were made but after hearing that the LS and the nh are the same machine just makes me wonder if all the cut's are in fact the same...one just being the "name brand" and the other's being an off shoot of the original. i'm not married to the idea of a nh..just like the way the look and the curved hood for the extra vision but i'm open to suggestion for other machines if you guys have any input. but i'm in the $20k range on price for either new or used but a FEL is a must as well as 4wd.
/ hello all #6
20K will get you a good new CUT, I paid $21000 and change for my CK35HST w/ loader. If your not married to any one brand look at them all. Deere and Kubota will try to tell you every other tractor is junk, but they're all pretty well built and will all work great. Parts for ANY CUT are expensive, not only the name brands. Almost all modern CUTs have curved hoods and loaders now, square is an older look. Kubota, Deere, and Case/New Holland are in the upper part of the price range, Massey Ferguson and Mahindra are in the middle, and lower down is LS, Kioti, TYM, etc. All have a good reputation, but the green and orange paint seems to be expensive. Kubota is about the only one that makes the entire tractor themselves, all the rest either have the entire tractor made by someone else, or many of the parts. The some cases the manufacturer that makes rebranded tractor for one the big 3 makes the same tractor under its own name at a lower price point. There are some CUTs that bad quality, but those are easy to spot. Look through the various forums here, If you see a forum for a specific brand, it's going to be a fine tractor. Most modern tractors now have 4WD, HST, curved shapes, and other great improvements. As you seem very concerned with the ergonomics of the machine, looking new (LS, TYM, Kioti) is probably a good idea. If you look around, there are some good deals on used machines out there though. What are you going to do with the tractor? If you tell us that, we can help with size and specific brand options.
/ hello all
thanks a ton TJP89...u guys seem to be extremely well versed on these issues and i appreciate it. i currently have an 81 ford 3600. i bought it just to bush hog with and pull a small trailer around my farm. but lately i've seemed to be borrowing my step dads bota and i'm just wondering how i've ever done without a FEL. i won't utilize the tractor like you guys probably do but i will be bush hogging a pond levy, moving dirt piles from time to time, pushing downed trees out of the way after storms and most importantly hanging deer from the FEL for skinning lol. 40hp was just my magic number since thats what my 3600 is but it may be more than i need. one of my main concerns was trying to get a newer cut with around the same wide stance as my 3600 bc i nomally mow with the levy instead of up and down (it's pretty steep) and just put it in gear and stand off to one side just in case it starts to tip but it never has...it just slides down hill a little in certain spots and when it starts doing that i just turn into the slide and start over. my worry is that with the more narrow cut's that they may tip so ill prob never try it and just mow it up and down since ill have 4wd on the new one. is was looking at the LS online just now and they are pretty sweet looking machines but i noticed that the engine hp is 40 and the PTO is 30.8. i assume that that drastic of a drop is due to the hydrostat? should that be a concern? should i look at a hydraulic shuttle? ive read that if digging dirt with a clutch machine or trying to inch forward that ull eventually burn up a clutch so that's why i wanted a hydrostat..plus i love to operate my step dads hydrostat way over my standard 3600.
/ hello all #8
When your back at the N.H. dealership, ask them about LS making their tractors. They will start stuttering! I did it on a Boomer 30 that was 3 years old and was priced about the same as an LS 3033, the guy about stroked out when I told him he was crazy for what he was asking. I said I can buy a brand new LS with 5 year warranty for $15,500-$16,000. They still have their Boomer 30!
/ hello all
haha...prob won't be back at the nh dealer..they only sell the nh and mahindra. but u know he was pushing the mahindra on me way more than the nh's. telling me all about the better warranty and all.
/ hello all #10
Yes, you will lose a little power with a HST. Look at the stats for the same tractor in gear and HST, The PTO power on the HST will be lower by about 2 or 3 HP. Not a concern, buy by PTO HP, not engine HP. What size is your brush hog? The general rule is 5 PTO HP for every foot of mower width. As you've found out, HST is a ton better than gear for loader work, even over a hydro shuttle. If you are going to keep the Ford, you'll have a hefty pulling tractor anyway. A 30 to 35HP modern CUT will outperform an older 40 HP tractor in almost everything except shear pulling power. As I said before, probably worth your time to look a 30 to 40HP CUTs new, plenty of options for 20K.
/ hello all
i like that rule of thumb about the 5 pto for every foot of mower. i use a 6ft mower so that will be just fine i think. i just ran up to the LS dealer and he quoted me a price of $22400 for the LS SR4040H...does that jive with what u are seeing in ur area? he said its exactly the same machine as the 4046h just 6 les hp. i really like it but i haven't drove it yet due to the fact that it was buried in snow and it's currently around 10 degrees at the moment. my friend is concerned with me buying an "off brand" due to the fact that he watched the same dealership that i just went to sell "montana's" and "mccormick's" and he said that he wonders if u can even get parts for them anymore since they've went out of business. would that need to be any concern for buying a LS since a previous poster said that LS makes the boomer and the case?
/ hello all #12
I'm not up on the maze of who makes tractors for whom now, but I think LS makes tractors for somebody right now. Montana and McCormick did not go out of business, McCormick is the same as Kioti, and Montana is now TYM. LS doesn't have a reputation like JD, but they are certainly finding a market and many here swear by them, I wouldn't worry about them being an off brand. I actually looked hard at the LS R3039 back in August when I bought, but mostly for weight reasons went Kioti. I really liked it. I was quoted about 24K, so you have a good price. A 6 ft mower should be fine on a 40HP tractor. Usually cold weather and snow are a major deterrent for me doing tractor work:D
/ hello all #14
Yes, the LS XR4040H is the same machine as the XR4046H with a bit less power (same engine, different tuning), and the price sounds about right. That will be more than enough to run a 6' brush hog.
Right now the fact that LS makes the same machines for Case and NH, is a positive thing...or at least it seems that way to me. The more machines sold (total), the more parts will be required, so there's a market to be served, and profited from. It will be in LS' interest to stick around and supply those parts over time. Further, if they weren't serious about the SCUT/CUT tractor market in the U.S. they wouldn't have started selling under their own name.
I wasn't concerned with the McCormick and Montana history, because those companies had problems, not LS. I don't the same thing will happen to CaseIH, or LS, and LS has been one of, if not the fastest growing tractor brand the last few years. One thing to consider is that LS is a spinoff of LG, which is a massive company, and is controlled by the same family....they have very deep pockets. Some people have suggested they're keeping their tractors at rock bottom prices to gain market share, and then they'll crank the prices up. This is the model that Hyundai, and Kia, followed....you can now buy a $75K Hyundai! There is actually some family history common between Hyundai and LS if my memory is correct. The Korean companies are being very aggressive, and this seems like more proof of that.
In all fairness, my LS wasn't perfect (no tractor is) and I always wished that it had a bit more FEL lift height, but I don't think that would bother many people. It could have had a bit more foot room, and a seat that went farther back, but those two things seem to be improved on the XR series. Other than that, I can't see many machines offering as much in the value department.
/ hello all #15
. . . i nomally mow with the levy instead of up and down (it's pretty steep) and just put it in gear and stand off to one side just in case it starts to tip but it never has...it just slides down hill a little in certain spots and when it starts doing that i just turn into the slide and start over. . . .
:eek: :eek:
/ hello all #16
Yeah I kinda winced when I read that part, That's just not smart. Don't do that with any tractor, no matter how wide. You may get away with it for a while, but eventually it will probably get you.
/ hello all
thanks GManBart....that was very helpful. it kinda helped solidify my decision. i'll check back in and let ya'll know when and if i get my new machine. again thanks to you all!!!
/ hello all #18
Regarding CUT'S...
Kubota makes their own.
Deere now apparently makes their own.
Daedong (sold here as Kioti) makes their own.
TYM makes their own.
Kukje (sold here as Branson) makes their own.
LS makes their own (but uses some of their own engines, and some Shibaura engines).
Yanmar makes their own.
Mahindra makes some of their own, and buys some from TYM, and some from Mitsubishi.
Massey tractors are built by Iseki.
Case & NH are built by LS (except the BOOMER CVT models, which are NH & Shibaura).
McCormick tractors are built by Kukje currently, but the last generation was built by Daedong, and before that built by LS.
Cabella's tractors are made by TYM.
Montana tractors were made by LS.
... I believe that covers the current CUT offerings.
New/Unused Landhonor 20ft x 20ft Carport with Side Walls (A61166)
New/Unused...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2013 Mercedes-Benz E350 Sedan (A61569)
2013 Mercedes-Benz...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
2022 J&M TF212 Rolling Harrow (A63116)
2022 J&M TF212...
JOHN DEERE 7330 PREMIUM TRACTOR (A62130)
JOHN DEERE 7330...
