Battery Tender
/ Battery Tender #1
BXman98
St. Albans VT
Kubota BX2370
Hoping to buy a battery tender for my BX this summer. Will this significantly increase the life of the battery? I also think that I need to top off the anti-freeze in the BX and I was wondering if I have to use a Kubota version anti-freeze or can I use normal 50/50 vehicle anti-freeze?
/ Battery Tender #2
I use bat tenders on my boat and suburban. Definitely help with the boat. Batteries were Everstart and lasted 8 yrs on the boat.
The suburban sits most of the time. Tender keeps the system from draining the battery. Bat was 10yrs old when I replaced it.
As to the anti-freeze as long as it is the same type you should be able to use any brand.
/ Battery Tender #3
/ Battery Tender #4
I've got a Schumacher battery maintainer from Wal-mart for $20. Works fine. It came with the connections that stay with the battery and alligator clips. Mostly use it on my quad and occasionally on a car that's not being used much (like my summer convertible).
I just ordered a 2 pack of solar maintainers from Northern Tool. At $25/2 I had to give it a try.
/ Battery Tender #5
For engine coolant,your Kubota uses plain old green antifreeze.
It hasn't been used in cars for some time now.
Find it at the dealer or an auto parts store.
For best results,mix 50/50 with distilled water.
Good Luck!
/ Battery Tender #6
A battery maintainer will help extend the life of the battery. You need to use ethylene glycol antifreeze.
/ Battery Tender #7
Here is a Battery Tender thread that has been running on T-B-N since February 2014:
Ta for the links 'jeff'! I didn't know that there was a difference between a trickle charger (which I have) and a minder/tender. Because of that I didn't bother to look at those links.
I looked at this link due to a niggling feeling that perhaps this wasn't one of those 'language barrier' cases between US & Australian English (ie: wrench = spanner or J-cloth = CHUX)
/ Battery Tender #8
I also got a Schumacer at Wally world and after 6 months is crapped out and over charged the battery. Now I only get the Battery tender brand at Wally world. A bit more but I think it is worth it.
/ Battery Tender #9
+1.....same experience here....but they(2 of 'em)...did last till just beyond the warranty.
/ Battery Tender #10
the harbor freight ones willl work but be careful and keep an eye on your electrolyte levels. i had a battery on our ford 800 that totally dried up with the battery tender on it for several years with infrequent use.
/ Battery Tender #11
A real battery tender won't do that. I have one on my 25KW generator that has been on continuously for 7 years and the battery is still fine.
/ Battery Tender #12
The quality and function of the charging device will determine if it maintains or even damages the battery it is connected to. A maintainer/tender/trickle charger is a low current charger, designed for long term use.
/ Battery Tender #13
There's a make of battery tender made by a company called Battery Tender. That's what I've been using for quite some time on generators. Tried almost everything on my portable generator to keep its battery up. Nothing worked until I bought a Battery Tender. Now I have one of the all weather ones connected to my 12.5 kw diesel generator. Tried a solar one there, but it wouldn't do. Have a solar battery tender on the battery for my electric fence and have 2 solar ones on the battery to our gate.
Battery tenders sense the battery voltage and don't put juice in unless it's needed.
Don't use an indoor (cheaper) one outdoors. Had an indoor one initially on my diesel generator. Even though it was protected by a cover where it was plugged in, it failed. The outdoor one (more expensive) now on the generator is quite old. Old electronics keep going though unless they get fried by something.
Ralph
/ Battery Tender #14
Are the battery tenders you all are speaking of made in Florida? The reason I ask is if so they are used on E-ONE fire trucks as standard equipment. If these are the same they do work great.
/ Battery Tender #15
Yes, DeLand, FL
2020 International LT625 48" Sleeper (A62613)
2020 International...
2017 Versatile 260 (A64126)
2017 Versatile 260...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
Valley Pivot Point (A64127)
Valley Pivot Point...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
