Is this right? I can tow MORE with a bumper pull than I can a Gooseneck?
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #91
Note that the PDF says "Factory-Installed Trailer Hitch Receiver Options" you can change to a different receiver to get more capacity (up to your axle weight limits). Here are some rated for a 17-20k pound trailer with 2500-2700# of tongue weight: 2014 Ford F-250 and F-350 Super Duty Trailer Hitch Class V | etrailer.com
Aaron Z
I actually think it has a heavy hitch installed as it came with a sleeve that would reduce it for the 2.5" insert I will have to take a look. I ordered it with the goose neck fiver package so a couple of hundred buys me the ball and chain connection decisions eh?
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #92
True, but those ratings (850# or 1850# max tw and 18,500# max trailer weight) are for for the OEM 2.5# hitch. The ones I linked have a max tw of 2500# or 2700# and a max trailer weight of 17,000# or 20,000#
Aaron Z
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #93
Aaron Z
yes, but you are assuming that the limiting factor is the hitch for the ratings he posted. That may not be the case.
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #94
It would appear that both Curt and Drawtite feel that the hitch is the limiting factor. Its not the rear axle (based on the 5th wheel towing specs) but it could be the frame.
Aaron Z
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #95
When the sleeve is removed the opening is 2.5" which I believe is a class five hitch
The truck was ordered with the heavy 14,000 GVWR payload package, camper package, fiver/gooseneck prep and trailer tow package and the hitch has a sleeve that when removed brings it to the 2.5"
does anyone know if this is a class v hitch?
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #96
2.5" means Class V, but not all are created equal.
Aaron Z
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #97
Aaron Z
I will have to take a closer look, It is up at the farm, I bought the truck to haul a camper not thinking of an equipment trailer lol.
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
