Lower lift arms
/ Lower lift arms #2
I think a good bet is enter - lower lift arms or 3-point arms into the google custom search box. Upper right corner of this page. It will get you to threads discussing damaged arms and where folks got new ones.
BTW - Welcome to TractorByNet(TBN). Hope your day gets better.
/ Lower lift arms
I googled it and found a place in Louisiana called Stevens Tractor. Anyone know anything about them?
/ Lower lift arms #4
Yeah, they're reputable. I bought a few things from them in the past...no problems.
/ Lower lift arms #5
Don't bother with the ones from Tractor Supply if you are putting them on anything with some power behind it. I folded 2 of them with a Long 460.
/ Lower lift arms
Thanks everyone! I think I'll order a pair from Stevens Tractor. Not sure what you mean by "a long 460".
My tractor is a TU150F Iseki. I bought it with a tiller and that is what I use it for mostly but I also have a blade and a dirt scoup. The scoup is what I was using when I bent the arm. The arms don't seem to work very well to push with.
/ Lower lift arms #7
He was saying he bought generic lift arms from Tractor Supply and put them on his tractor, which is a Long 460.
Generally speaking, lift arms aren't meant for pushing, and you've already seen what can happen to them. You have to be pretty careful when using a scoop, or pushing with a blade, to avoid damaging the lift arms.
/ Lower lift arms
My lift arms are generic also as my tractor didnt have a 3point hitch when purchased. I will just have to be more careful from now on. Thanks again for all the help.
/ Lower lift arms
Got my lift arms yesterday. WOW that was fast. They are heavier than my old ones, which is good. I will put them on and try them out as soon as the weather warms a little. It is 5 degrees outside this mourning and I don't really have any pressing projects for now.
