Goose neck vs bumper pull
/ Goose neck vs bumper pull #41
My old 25+5 weighed 6400#. It had dual 12K axles and a 25,000# gvwr.
Chis
/ Goose neck vs bumper pull #43
My 28+4 20K dual wheel no ramps weighs 6800. I scaled truck/trailer, then unhooked and scaled truck to get that number.
/ Goose neck vs bumper pull #44
I am in Madisonville....you can come drive/pull mine....a bunch of us are near you
/ Goose neck vs bumper pull #45
To go along with everyone else,
My unknown brand 20+5 24k trailer is 6500# empty
/ Goose neck vs bumper pull #46
I don't disagree they pull better. It's all the limitations that come with them.
All I'm saying is think it out. I didn't in 2000 and bought a 25 plus 5 GN. Sold it 3 years later. Loss of bed space and inability to pull with our two SUV's made that decision for me.
Chris
Trailers are like boats in a way. Everybody needs two.
/ Goose neck vs bumper pull #47
/ Goose neck vs bumper pull #49
Ive got three trailers right now and need another one which will replace two. So I'll still have two after its all over.
I had to do some math, I've got 4 trailers. :)
/ Goose neck vs bumper pull #51
Same here 4 and 2 frames for couple small trailers I never finished
/ Goose neck vs bumper pull #52
I have been browsing GN trailers. When the time comes, I was considering an adapter plate that uses the rails in the truck. Like this link.
Compatability of a Goose Neck Plate with Reese Universal Mounting Kit and Rails | etrailer.com
Otherwise, I thought the disadvantage to a 5th wheel hitch on a utility trailer is motion is limited, which may affect folks who drive off road, in fields etc.
I am looking at getting trailer for my compact and have a 40' fifth wheel and was wondering if there is a disadvantage to just getting the trailer for my tractor with the tongue for the fifth wheel hitch?
/ Goose neck vs bumper pull #53
I have 3 trailers. That's enough for now.
Chris
/ Goose neck vs bumper pull #54
Even though there is more weight on the hitch, its effets on the truck are less cause its directly over the axles. A bumper pull that hitches several feet behind the axle gives the trailer lots of leverage.
Think of putting a pallet of whatever right at the back of the truck (half on the tailgate) vs shoving it all the way to the front of the bed. Same weight, big difference in how the suspension handles it.
One thing to keep in mind too, is GN's turn short and cut corners. You need WIDE driveway approaches to get into and out of. If you have a narrow drive, you may either have to change that, or stick with BP
Amen on narrow driveways. Backing a GN is a whole new world and if the Driveway is at all narrow and curved you need way wider ...
/ Goose neck vs bumper pull #55
I think it all comes down to weight and length if your 22ft and under, less than 10k stay with the bumper pull. Over 24ft and up go with the gooseneck. Just my two cents. (well may not even be worth two cents)
/ Goose neck vs bumper pull #56
Bidding on another disc! Rb auction? I hope you get it. Looking forward to seeing ya soon!
Brett
Brett,
I didn't get it. They started the bidding at my "high" price and it went up to $2000. I would have went on and bid higher.........but this one is in pieces and is missing all hardware to assemble. It also had a frame crack near the tongue. I wanted it, but have too many projects as it is now. I was going to fix it up and resale it. As it was.............disassembled...........it would have taken up all my dual tandem trailer's footage. I need a longer trailer!
But all is not lost.............timed bidding continues tomorrow. Yippee!
hugs, Brandi
/ Goose neck vs bumper pull #57
What size truck are you using to pull these? Now I am questioning my F250.
I pull my 28 GN with an 02 GMC dually with Duramax. Even with the trailblazer loaded it does a super job. I load it to 14,000 on the axles and I think the total weight for truck and trailer full was around 23,800, on my last load. I'm not sure what the truck is rated for but that had to be close to maxing it out, but maybe not. The truck is 7500 and the trailer is 6000 approx so that leaves 10,300 for weight on the trailer. That doesn't seem like much, but maybe my math is fuzzy.
/ Goose neck vs bumper pull #58
Brett,
hugs, Brandi
Isn't it crazy what people will pay for equipment!!! In my territory I'd have struggled to pay $2K if it was field ready!!!! I bought a light duty 12ft tandem wheel disc from the local scrap yard for $128. It needed two bearings replaced. Tires even held air and are useable. I used it a lot last Fall doing some seeding.
/ Goose neck vs bumper pull #59
WHY CAN'T I FIND THESE DEALS?...
/ Goose neck vs bumper pull #60
I tow with an f250, 7.3 diesel and my trailer is a 20ft pipe top with 7k axles. When I went to my new tractor it weighed more. With loader, boxblade(#1100) or brush hog the weight I think is between #7500- #8000. Trailer is about #3000. Tongue weight was about #1100. Even though it is within limits the last time I drove 1500 miles it was very nerve racking to drive and not comfortable. I also had about #500 in the bed of the truck.
Sounds like the perfect use case for a WD hitch.
Given you already have the trailer, and its going to be lighter overall weight than GN version. Id stick with what you ahve and add a good WD hitch. It makes a world of difference on my E350 van.
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
(1) 94"X60"X3/4" STEEL PLATE (A64281)
(1) 94"X60"X3/4"...
2000 EAST 8' X 45' T/A WALKING FLOOR CHIP TRAILER (A64280)
2000 EAST 8' X 45'...
2015 Hyundai Veloster Hatchback (A61574)
2015 Hyundai...
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2017 Takeuchi...
(10) HYD OIL PUMPS FOR DUMP TRAILERS (A64280)
(10) HYD OIL PUMPS...
