an old welder (with armature)
   / an old welder (with armature) #21
Theres a 3-phase swing crane and a traveling gantry crane nearby (but no outlets!). Could that plug be anything other than 220v single phase?
I saw that too. Looks like a 220 volt 'crowfoot' plug to me.
   / an old welder (with armature) #22
That doesn't mean someone didn't try to hook it up to single phase. But like I said I don't know if they're 3-phase or single phase.:confused:
One thing I do know, they have a very sweet arc!:cool: But very high pitch scream to them.:eek:
   / an old welder (with armature) #23
ive used these quite a bit years ago...I don't remember the scream? but I do remember one smooth steady arc! they were great welders! im thinking the problem was too many moving parts and as they wore out they were replaced with cheaper transformer machines. I rarely run into them anymore and when they do show up there not wired so I fig they broke and were forgotten about.
   / an old welder (with armature) #24
As far as I know those Lincoln motor generator welders were all three phase. The large horizontal ones went up to 600 amp output. They were pure DC welding current with controls similar to the engine drives so you could fine tune the volt-amp characteristics
It looks to me like the machine was in-use (for years) with that crows foot plug.
So,,,,, should I plug in in to a 220 dryer outlet and test it? Or was there a crows foot outlet that is 3phase (& no ground) in the old days? This thing has an "inventory date" of 5/71 written on it.
   / an old welder (with armature) #26
I'd ask on Welding Web, there is a moderator there that goes by 7A749 he repairs welders for a living. He would know if these things came in a single phase version.
   / an old welder (with armature) #27
See if one of the plug's prongs is connected to the case/frame. That would be the ground.
   / an old welder (with armature) #28
generally used for air arcing now
2012 Chevrolet Silverado 3500 Ambulance Body VIN # 1GB3K0CL2CF118201 (A57453)
2012 Chevrolet...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2018 International WorkStar 7500 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2018 International...
Case IH MX270 Tractor (A59814)
Case IH MX270...
