1ST TRACTOR, FIRST MEMBER
/ 1ST TRACTOR, FIRST MEMBER #1
packmule
ohio
JD790
Hello,
finally have my first tractor, JD 790. very excited. had a question about a brush hog. have a used TSC 5' brush hog used and seems to drag the wheel on the thing. looking at it maybe have little lean to one side and didn't know if that's the issue for not tracking straight or not. not real sure about how it should be adjusted. top link tight or not, that sort of thing. any help woudl be great.
thanks,
/ 1ST TRACTOR, FIRST MEMBER #2
Welcome to the forum. I'd go to TSC and look over a new one,check and compare the wheel angle on it with yours.I had the same problem with mine years ago my fork shaft was bent back way to far.
/ 1ST TRACTOR, FIRST MEMBER #3
Welcome from Wisconsin I have agree take a look at the new ones.
/ 1ST TRACTOR, FIRST MEMBER #4
Welcome to TractorByNet! I have moved your thread to the JD forum. :)
/ 1ST TRACTOR, FIRST MEMBER #5
Welcome to TBN from out West!!
/ 1ST TRACTOR, FIRST MEMBER #6
:welcome:
To the forum from Alabama. Could also be that the shaft on the wheel needs grease. On my LP cutter, it says to grease every 10 hours. They do freeze up if not greased.
/ 1ST TRACTOR, FIRST MEMBER #7
Hello,
thanks,
Make the top link as loose as possible. In fact, I removed the steel straps (not sure what your configuration is) and replaced them with chains so the rear of the brush hog could float.
/ 1ST TRACTOR, FIRST MEMBER #8
Welcome to the forum! I think you're really going to like the 790, I know I like mine a lot! Good luck with it and take the time to learn it. I think the possibilities of the problem with the tail wheel on your mower have already been answered. This place is GREAT for getting lots of free information and advice!
/ 1ST TRACTOR, FIRST MEMBER #9
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
1998 JD #8300 MFWD (A68191)
1998 JD #8300 MFWD...
PALLET OF MISC ITEMS (A68842)
PALLET OF MISC...
MQ MULTIQUIP PUMP (CONDITION UNKNOWN) (A68842)
MQ MULTIQUIP PUMP...
