hydraulics stalling engine
/ hydraulics stalling engine #1
Mustache
Member
Ottawa
Massey Ferguson 1560
Hi everyone, my Massey Ferguson 1560 has a problem where the hydraulics stalling the engine.
To be more precise, running the PTO will stall the engine after a while if it runs without load and the fluid gets hot. Front loader hydraulics will stall the engine as well. After the hydraulic fluid gets hot enough, I can't even drive it any more than 10 feet or the engine stalls as well.
Just before this issue started I got a new snowblower with 2 hydraulic functions. Well, an old blower, so I am wondering if dirt in the lines may have screwed up the pump? I already changed the hydraulic fluid and filter (not many metal pieces on the filter magnets, so no issues there I think).
I wonder if its worth it taking the pump off / apart (I have to learn this first) or am I completely off track here?
Any advice appreciated!
Thanks folks!
/ hydraulics stalling engine #2
Check your relief pressure with a hyd gauge.
Not sure how to do that or even where to get the gage. Regardless of that, what should the gage read and depending on that, what could be wrong with it?
Thank you!
/ hydraulics stalling engine #4
I wonder if you have a dead-headed hydraulic circuit somewhere. That will make troubled for the pump, if so.
/ hydraulics stalling engine #5
Exactly - a dead ended/completely blocked off hydraulic line and J_J's pressure gauge should show almost instant high pressure. In the absence of a pressure gauge - disconnect the lines used for the newly acquired snowblower and see if the problem is corrected. If it does - you have isolated the area of the problem.
I did run it without the blower, but running the front loader. No PTO engaged either. I still had the same problem of the engine bogging down. Not sure if I said before that after a while even driving bogs down the engine. The hydraulic fluid is also the transmission fluid.
I'm reading through my service tech manual and there is only the main filter, no other screens. It technically could be any one of the valves too I guess? There are 2 outlets, 1 PTO valve, the loader valve and it looks like there is a shifter valve too. And of course main and sub pump.
I'm inclined to see if I can take the pump of and have it tested somewhere. If that's possible at all.
/ hydraulics stalling engine #7
In open center hyd systems, with all valves in neutral, the pump flow passes through all valve to tank.
If your engine is stalling caused by the hyd, then you have something connected wrong. Perhaps your snow blower valve.
Are you sure all valves are in neutral?
Are all valves open center?
/ hydraulics stalling engine #8
Thank you!
Here is one place, Surplus Center:
3000 PSI 2.5" LF LM GAUGE
/ hydraulics stalling engine #9
I don't think you have a pressure problem so a gauge won't help much, (and I sell them by the way) obviously the pump is creating enough pressure to eventually stall the engine.
What I belive you have is a flow problem, in that it's blocked. You say this started when you added a snowblower with two controls? My guess is that the valve on this blower might be closed center and its blocking the flow, causing the relief valve to open, and then overheat the fluid (that's probably burnt now and needs to be replaced when you get this issue sorted out)
Can you tell us more about this blower? Maybe show some pics of how its hooked up?
/ hydraulics stalling engine #10
I agree with Kenny that you have a flow issue. Best get this fixed before you damage some components.
Thank you everyone for your replies. I decided to get the tractor floated to the mechanic. The shop is usually not a parts seller, so I'm hopeful they will be able to figure it out.
Kenny, the blower auger is powered by a PTO shaft directly to the 540 PTO takeoff. Then I have 4 hydraulic lines that power chute rotation and deflection angle. Deflection is a short hydraulic cylinder and rotation is a hydraulic motor. Each put some strain on the hydraulics, but don't cause it to stall like loader work or mostly the PTO.
I do agree that something is causing a blockage, but I did not know how to debug this without hydraulics knowledge.
I will try to remember to post the outcome, I really hope its nothing too bad.
BTW, my first step was to replace hydraulic fluid and filter and it improved some, but not much.
Thanks again everyone!
Update: the dealer did everything to recreate the problem, but it just didn't happen for them. Thing is, the weather was a good 10 degrees Celsius warmer than when I had the issue.
However, I got my tractor back today and here is what I experienced. First off, in idle with the gear shift selector in the middle range, the tractor creeps now forward. It's not the forward/reverse selector I think, I have to try some more, but that is a new issue.
The bigger thing is, I wanted to hook on the front loader and it didn't work. The hoses all connected fine, but the left main lift cylinder didn't work at all and the right one only lifts, but not lowers. Now I'm not sure if its the loader or the valve at this point, I have to do some more research and talk to the dealer as well.
As always, any feedback is appreciated.
Thank you!
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
