Alternator b2320 kubota
/ Alternator b2320 kubota #1
pat80014
salem nh
b2320
After adding lights. radio, and heater. The stock magnetic alternator does not keep up. Do they make something that is that small and produces more amps?
/ Alternator b2320 kubota #2
:welcome:
To the forum. How many amps is it now?
/ Alternator b2320 kubota #3
According to tractordata.com there are two available alternators. A 14.5 amp one and a 40 amp one.
/ Alternator b2320 kubota #4
Yes, there is an alternator upgrade kit available. From Kubota whole goods it is only around a $100 I think.
/ Alternator b2320 kubota #5
I upgraded mine with the 40 amp kit about 10 years ago. I paid $200 CDN, but our loonie had tanked back then, just like it's doing again now.
/ Alternator b2320 kubota #6
Change your lights to LED lights , they draw very little amps.
/ Alternator b2320 kubota #7
Call Kubota and ask them if that 40amp upgrade is the magnet type, or is it a true self contained alternator. Your engine is only rated at 23 gross hp. Those magnet type units are nothing more than a magnet spinning around a stator assy. inside the housing. The ac voltage it produces is converted to dc voltage via a rectifier/regulator which is mounted somewhere on the tractor. Follow the 2 wire harness from the magnet generator & you will find it. If the 40A unit Kubota offers is a magnet type, then it would be a direct replacement bolt on, but I would ask them if the rectifier/regulator unit would handle the additional amps. If it's a true self contained alternator, then some wiring changes will need to be made. The true self-contained alternator would have a built in regulator, and would work just as well, with the additional wiring mods. needed. I used to work for my family's business for 25 years, we were an automotive service and parts whse., and we rebuilt starters, alternators, generators, magneto's, etc. for the AG/truck/marine industry's. I now work for a John Deere/Kubota/Volvo engine distributor, and I am quite familiar with starting & charging systems on off-road vehicles...:thumbsup:
/ Alternator b2320 kubota #8
The 40 amp alternator kit is a true automotive style alternator. The kit comes with a small Denso alternator, a different drive belts, and instructions. You end up removing the rectifier assembly and changing the wiring a bit if I remember correctly.
/ Alternator b2320 kubota #9
If that's the case, and it's available in kit form with a true denso type AG style alternator w/built in regulator, that's what I would opt. for! Just be ready for sticker shock on the price of that kit, the alternator by itself is probably over $200. alone! Then again, sometimes the mfg. will surprise you with a kit price...:laughing:
/ Alternator b2320 kubota #10
According to the Kubota website, you need B7311, high capacity alternator kit. Build my Kubota shows pricing at $192. You will probably want to order this through Kubota whole goods rather than parts. Check with your dealer or try one of the Kubota dealers on the forums.
