No hydraulics!
/ No hydraulics! #1
tinker 75
Midcoast Maine
Kubota L3240
Went to move the snow from last nights storm FEL was working fine. Unhooked it hitched up the plow it tilted one way then it lost all power. I unhooked the plow still no power. The backhoe, the FEL nothing. Thoughts?
/ No hydraulics! #2
My first thought is to check the quick connects to make sure they are seating properly. I assume fluid levels are correct.
/ No hydraulics! #4
The way you describe it, all hydraulic function has been suddenly lost. My thoughts are
something physically disconnected between your hydraulic actuator lever and the valves or
pump quit
/ No hydraulics! #6
you are saying that you have no hydraulic pressure in any of your hydraulic lines, front or rear, actuated by different levers...that would lead me to question hydraulic pump although I can't explain why there would be a sudden failure, as you describe. But pump internals are not my thing.
/ No hydraulics! #7
When was the last time you pulled the strainer? Also, could be a plugged or collapsed filter or hose. Do you hear the pump when the engine is running?
/ No hydraulics! #8
Just recently another poster had hydraulic issues. He a plugged strainer, ice and water in the oil.
/ No hydraulics! #10
filter and hoses are fine, where is the strainer?
Should be at the base of the hydraulic tank or base of tractor depending on your model. Should be a line to the hyd. pump. Your OP manual should show you where it is.
/ No hydraulics! #11
Hey tinker, did you get this solved?
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
2023 Isuzu NRR Crew Cab 20ft Dovetail Flatbed Truck (A61573)
2023 Isuzu NRR...
