BX25 Stalling out
/ BX25 Stalling out #1
benabrazil
easton, pa
Hello, I have a BX25 that was purchased in 2011 with ~150 hours on it. It recently started to stall out and in doing some research, it appears that it could be a wire, fuel filter, or a blockage in the line. Any recommendations on what to rule out first when inspecting the tractor. Any help would be greatly appreciated.
/ BX25 Stalling out #2
If the filters are transparent look for signs of water in the fuel. Could the fuel have gelled?
/ BX25 Stalling out
This could be a possibility but it was running fine for about an hour before it started to stall. This also happened to me a couple of days ago so I let it sit then started it up again and it ran for a couple hours after that. I let the tractor run for a couple hours to burn out the fuel just in case it was that reason and replaced it with new fuel and it started again today but today it is just stalling out. How can I quickly check if it gelled? Should I put it in the garage to let it warm up?
/ BX25 Stalling out #4
Warming up will help if some water is freezing in the lines. Gelling or frozen water would plug up your filters. It may be the filters are plugged.
/ BX25 Stalling out
I did some research online and asked the dealer and it doesn't seem to hard to replace. Any insight/tricks on changing or unglogging the filter?
/ BX25 Stalling out #6
It usually the rear filter, its fairly small and an opaque white thing. Don't get it confused with the lift pump, which is a metal silver unit, but about the same size. The only tip I have is just figure you are going to get fuel all over your arm. I usually just have the new one handy and jam it on quick and hook it up.
/ BX25 Stalling out #7
Amazon.com: OTC 4506 Fuel Line Clamp Set - 2 Piece: Automotive
[edit] Forgot link to fuel hose pinchers.
/ BX25 Stalling out
Thanks for the info. The weather warmed up and I got it to run and it seems to be fine for now. Is there something I can put in the fuel to help with moisture or something I can do to avoid this all together? I will be picking up the fuel filters and changing them in the new future.
/ BX25 Stalling out #9
I've had the same problem off and on since I owned my BX. I finally gave up and put on a Racor fuel filter. If you do a search, you can find some threads on adding one. I put it off several years and finally gave up and installed one. I had the same problem you describe and it happened to me about 3 or 4 times. I'd pull the rear filter and even cut it open a couple of times. You couldn't blow air threw the thing it was so plugged up but when you cut it open, it didn't look that bad. It always happened to me in the winter. In my opinion the factory filters are inadequate for a diesel engine.
For additive I use Howes or Power Service, but they didn't help with my problem of the rear filter plugging.
/ BX25 Stalling out #10
Just went through this yesterday on my BX1500, long story short I replaced both fuel filters, thawed the fuel lines from the tank forward with heat gun, as it was frozen up with milky water in the lines between the tank and the pump. I let the bottom of the tank drain out into a bucket before putting it all back together. I pumped fuel through the pump to flush it out before connecting line to the filter. I'll add in it was a blast laying on my frozen icy driveway with snow starting to come down before the storm. I had used the tractor Sunday without issue.
/ BX25 Stalling out #12
What are we looking at here and does it help with the fuel filter?
Sorry, must have hit "post" before I put in any text, and got distracted by something else....
Those are nice little fuel hose pinchers. I've used small vise-grips before but these don't risk damaging the rubber fuel line and aren't as heavy. I use them when changing fuel filters to minimize the spill.
Z.
/ BX25 Stalling out #13
I must be very lucky. I have never had water in my fuel or fuel gel on me. I do add Power Service to the fuel year-round and don't store bulk fuel. Maybe that has protected me.
Good luck getting it cleaned out.
/ BX25 Stalling out
Thanks again for all the help. Very much appreciated. This forum has more than exceeded my expectations.
/ BX25 Stalling out #15
/ BX25 Stalling out #17
I've had real good luck with Diesel 911. It should be readily available in PA. About 4 oz per 5 gallons works for me.
Sent from my iPad using TractorByNet
/ BX25 Stalling out #18
Interestingly with my BX it was frozen between the tank and the pump. I worked from the engine back, figuring the filters, but hey they were dirty anyway and due for a change. What are your thoughts on putting a separator / filter between the tank and pump to catch any potential water/contaminants directly from the source?
/ BX25 Stalling out #19
I have a little 2cyl B4200. I have never changed the fuel filter in 10-12 years. It still looks clean. My old B4200 has a nice screen on the fuel filler. My new B3200, any thing can fall into the tank with the big filler cap off. Anyway, the only issue I ever has was bleeding the system when running out of fuel (no gauge). My tractors are out in the freezing weather 4 months of the year. Maybe we have better cold weather diesel up in Canada. I would crack the bleeder valve for a few minutes in case you have a bit of air locked in the line.
/ BX25 Stalling out #20
I pretty much did the same as the link above that shows how Scooby mounted his filter. I don't have a welder and messed around quite a bit before I mounted it in the same place as Scooby.
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A61574)
2010 Mercury 15HP...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
Deere 700K (A64126)
Deere 700K (A64126)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
1996 International 4700 (A64127)
1996 International...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63688)
2019 Cadillac XTS...
