Mule 4010 & BOSS V plow
/ Mule 4010 & BOSS V plow #1
GreatWhitehunter
Eastern CT
JD 110 TLB
Figured since I like seeing pics of everyone's toy's, I'd post a few of the Mule with my BOSS.
I'm very happy with this setup and recommend the Boss V( abeit a bit $$$). This is 26" of light snow from the blizzard.
Matt
/ Mule 4010 & BOSS V plow #2
The Boss V plow is an absolute hoss when it comes to moving snow. I like how high it can stack in the scoop position. Although it was expensive it was well worth the money in my opinion, same goes for the Gator 825i I have mine hooked to.
How do you like your hitch mounted spreader? Does it throw sand as well as salt?
/ Mule 4010 & BOSS V plow #3
Very nice! We love all pics, thanks. Today's snow?
Still snowing here, I'm getting ready to go out for my 3rd plowing. I have a long icy (up) hill that I'm skeerd to wait till it's over, even with chains.
I run rock salt in the spreader but the controller has the vibrate controls so I could add a vibrator and run sand.
My driveway is a steep hill also it takes two passes to clear the driveway but I'm about to go back out and deck the banks incase we get more snow.
I don't need chains with the radial tires I put on. I'm thinking of looking into tracks but more for fun than work.
After this storm a cab is going on in the spring for sure. I had more snow in the mustache than I like.
Matt
/ Mule 4010 & BOSS V plow #5
Very nice, thanks for sharing. Might get a Boss straight or v plow for my RTV1140 for next winter. Did you have to add to the front end any (springs, struts) or is it stock?
Kawasaki calls for the HD spring kit when installing a cab or plow. I originally ordered the OEM springs but decided to go with a Highlifter lift kit to and larger tires. I found the highlifter springs to be stiffer than the OEM.
Matt
/ Mule 4010 & BOSS V plow #7
This thread brings back memories. Not fond ones. :confused2:
- djb <-- grew up in Ohio... :D
/ Mule 4010 & BOSS V plow #8
Nice set up! How do you like your salt spreader? I am thinking of getting the same one for my Kubota RTV x-900.
The salt spreader is ok, it's the larger hp motor with the auger. It's not the best made unit I've seen but I feel it's and ok value.
If money were no object I'd buy the new in bed Boss spreader but the saltdogg is adequte for the job.
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
72in. Fork Extension (A64553)
72in. Fork...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
