What flashight do you recommend?
/ What flashight do you recommend? #41
Looks like lots of good ideas but the Maglite seems to be coming out most often so far. Good thread.
/ What flashight do you recommend? #42
I have several Maglites (5 I think) that have held up very well.
I have at least a half dozen of the HF freebies. They work fine and are handy because the fit in your pocket easily.
I have two that are similar to the HF lites but also have a red laser. My wife uses those to entertain the cats.
I have some Tractor Supply LED lites in a couple different shapes. They are handy because they have magnets on the back to hold them in place while you work.
/ What flashight do you recommend? #43
Do you have a particular flashlight you like? I need to buy some new flashlights to replace my old bulb style Maglights and the sheer number of them is confusing.
What I would like is an LED that's bright enough to see in the barn at night and takes AA, C or D batteries. I'd like it to be a major brand so I can get parts if I ever need them and I don't want to spend $75 on it because I would like to buy several. Less is better but I'm not a cheapskate.
A couple months back I picked up some flashlights at Costco that take three AAA batteries and have three clicks on the switch. Dim, bright and flashing. It's sort of a hassle to go through the clicking cycle every time you use it. I bought three of these flashlights and so far one is broken, one doesn't work all the time and one rarely gets used. So I'm not happy with those. My Harbor Freight freebies have worked better.
What do you have and do you like it? Any ideas appreciated.
The BEST flashlight I have ever had. StreamLight Stinger DS LED. Came with 2 rechargeable battery packs, wall mount/charger for home, car mount and charger for car. Amazing bright.
/ What flashight do you recommend? #44
I got an LED conversion bulb for my 2 D cell Maglight from the local Ace Hardware store. I think it was the same brand mentioned 7 or 8 posts ago. Satisfied so far and much brighter than the Maglight 30 year old bulb. I think I bought this Maglight 35 years ago. If not it is 25 years old replaced after my truck was stolen. In any event the Maglights have worked well for our family. You can get the D cell lights repaired easily with a repair kit from Maglight. I did toss 3 AA Maglights in the recycle pile. I guess batteries leaked and I could not get them open. I assumed that penetrating oil would not get passed the o-ring seal.
/ What flashight do you recommend? #45
Responder RA Div. 2
This is the one I carry in my turnouts. Have also used out duck hunting. Mine is rechargable. Now they make them in LED. If I replace it, it will be with a Big Ed rechargable.
Pelican 3750 Big ED Rechargeable Firefighter & Industrial Flashlight FREE S&H 3750-001-245, 3750-052-245, 3750-051-245, 3750-054-245, 3750-051-247, 3750-000-245. Pelican Flashlights.
I still like Maglite. LED version work well.
I get the most use out of my DeWalt 18V that came with my 4-tool set(light, recip saw, circ saw, drill-driver). That thing has been everywhere with me. All around the house and property. Camping. Hunting. Battery last a long time on a charge. And, I have the charger that works from the cigar lighter in the truck(I guess they call them auxiliary power now). It gets used all the time! It has been on countless Boy Scout campouts. Dropped, bumped, accidentally kicked. Fell in pond. Sat on.
I like my other, a Makita 9V too.
Otherwise I usually use a LED mini-maglite.
/ What flashight do you recommend? #46
I'm pretty happy with my three flashlight's. I have a small AA Maglight that's probably ten years old sitting on my desk in my pen holder for those times the power goes out. Mostly it just sits there. In fact, I'm not sure when the last time is that I used it. Last year I bought my wife a rechargeable LED spotlight from Acadamy that has become the go to light when we go outside. It has a very long range, which is what she likes about it the most. She wants to see what's out there. I use it all the time to shoot raccoons stealing food from Oscar, my pet pig. And for those nights when the power goes out for awhile, or I just need a flashlight to see what I'm doing, like working in an attic, I use my Makita 18volt LED flashlight. It will last hours and hours with enough light to work, or just play cards with friends.
Eddie
/ What flashight do you recommend? #47
For X-Mas, I have been offered a LED head lamp. It has a casing on the back of your head containing three AA batteries. The unit has a single bulb, with a three fonction press "switch" button. Off-On- E. blinking. It has a well proportioned lens. The focus could range from spot, to wide angle (flood). Elastic straps are ajustable, so you can wear it over a tuque if needed, without having your brain compressed...
Of course, it is made in China (to my greatest regret), and all parts are plastic.
This kind of light stays with you at all time (ie: no droping:(...) and permits to work hands free (Big bonus). As it is head mounted, the light stays beemed where it is most needed, and this is in front of your eyes.
Of course, I have plenty of other lights and they have all been mentioned already in this thread.
May the light be with all:)
OK, I'm t he OP and here's what I did. I searched most of the flashlights suggested and decided to keep, but upgrade the Maglites I have, use my Makita 18V flashlight and buy some cheap LED lights from Costco mostly because they did an acceptable job and were cheap. I learned there are a lot of good flashlights out there.
Part of this was pointed out here about how good the rechargeables--like the Makita were. I do use mine frequently but--duh--I forgot about it so I'm going to rely on it more. The Maglites didn't get used much but I upgraded with Xenon bulbs and that improved the light dramatically. I've got four big D cell Maglites so that solved that problem. The Xenon bulb conversions were only a few dollars each.
Finally, I needed a small LED light for my pocket. Even though i'm not real impressed with my three AAA small Duracell Costco LED lights, they wound up being the go-to light for my coat pocket in the winter. They are very bright and all things considered I decided to keep and use them.
Now, to add to the above, because you can never have too many bright flashlights, I bought this 3-pack of flashlights at Costco today for only $16. Each one holds four AAA batteries and seems as bright as the sun. They are a little bigger than my current pocket flashlights but still fit and if they break, so what? I'm out $5?. So I'm good with all that.
All this got solved cheaper than I thought possible. Thanks to everyone. I can see clearly now.
Here's the new Costco flashlights. By the way, no dim-bright-flashing lights. These are bright-dim and no flash.
/ What flashight do you recommend? #49
...The Maglites didn't get used much but I upgraded with Xenon bulbs and that improved the light dramatically. I've got four big D cell Maglites so that solved that problem. The Xenon bulb conversions were only a few dollars each.
Thanks for following up, sixdogs. Mind sharing which bulbs you ended up with, and where they came from?
/ What flashight do you recommend? #51
A little late now, but I love MagLeds. I got a 3D and 3 of the AAs. Tough as nails. The 3d could double as a self defense weapon :laughing:
I also have a Pelican Stealthlight for work with a hard hat mount too. Its a very bright and tough light. Id like to get the LED version of it for home here, but I got a lot of lights as it is.
/ What flashight do you recommend? #52
MAG will warranty any light if it has "name brand" batts in it. All you have to do is send it in. I sent in a 3D and a AA that had blown batteries in them and Mag sent me 2 new ones. Great warranty service. Only downside was shipping from here in NS to California cost almost as much as the 3D could be bought for when on sale.
/ What flashight do you recommend? #53
The good news about flashlights is that we have such a choice of good ones to choose from. "Back in the day" when I was a kid, there were not many to choose from and they all sucked. Our modern lights are much sturdier, brighter, and longer lasting. Even the cheap "junkier" lights are better than the best we had when I was a kid. It all started with the Maglight revolution and just got better with the Introiuction of LED technology.
/ What flashight do you recommend? #54
I bought a Fenix TK11 with a CREE LED a few years ago and have been very pleased with. Lots of light output, two modes. I can typically see from my front porch down into my field on the highest mode, which is probably 2/10ths or so of a mile away. I run 1 18650 rechargeable battery in it and it lasts a while. I don't use it every day so that's one reason for the long charge. Typical use is about 11hrs on the lowest mode, and I think 3 on the highest. I won't go back to a regular light after having used this.
Rick
/ What flashight do you recommend? #55
Those CREE XM-L flashlights on eBay are hard to beat for the price. I have a dozen of them. Just don't buy those cheap 18650 batteries or chargers on eBay. They are just bad cells out of laptop computer battery packs shrink wrapped in a new wrapper.
For more than you ever wanted to know about flashlights check out this forum...
http://www.candlepowerforums.com
/ What flashight do you recommend? #56
I forgot, but the flashlight that I use the most is my the app on my phone.
Eddie
/ What flashight do you recommend? #57
Eddie
That is pretty funny, until I realized it is probably the one I use the most too, because the phone is always just right there.
/ What flashight do you recommend? #58
Late to the thread and I did not read all the replies and not sure if you are still looking but a while back Costco had this set:
FEIT Electric 500 Lumens High Performance LED Flashlights, 2-Pack - Tactical Flashlights - Amazon.com
which I bought. Later I also saw they had some Duracell branded ones that looked very similar. Both were two flashlights for around $20-$25 with batteries.
They have a CREE bulb and the 'zoom' feature is pretty awesome, you get a super bright patch the reaches out 50-75 or more yards (with new batteries) and makes it very easy to identify whatever is going 'bump in the night'.
You might still be able to find the Feit or Duracell sets on Ebay.
/ What flashight do you recommend? #59
