downsizing-what's out there and more ?'s
/ downsizing-what's out there and more ?'s #1
Snuffy Smiff
extreme NE GA
NH 1920 4WD
Hello all. First post here so bear with me. We have recently downsized the home and acreage from 14 acres to an acre and a half and I'm not exactly sure how much less machine I need.
A nice mid-size zero turn would likely work for mowing but after inheriting a 1997 Ford/NH 1920 4WD about 11 years ago w/Ford FEL, and a rear mount 72" finish mower I just prefer to go with a smaller tractor. Much more versatility and such. Would prefer to have small FEL capability, a decent ROPS/canopy, and not exactly sure on what type mower to go with as we do have a LOT of fruit and ornamental trees(here when purchased). So, would a belly or rear mount work best?
Mostly flat here so do I really need 4WD(locking rear diff may suffice)? Also would like to have small garden plowing/tiller capability.
What about trading it in? Is it similar to trading in a car or would I be better off selling it myself then buying something smaller? I really hate parting with it but it's just way more tractor than I will need here.
Lastly, does Shibaura still manufacture engines/tractors and for who-New Holland(I hope)? If not, what brand(s)do you recommend? The tractor I have now has been one exceptional machine and I'd like to stay with what works but-if something better is now out there...
Local dealer has JD, NH, and Kubota. I figure each brand has their finer points but so far I have managed to resist visiting the dealership. Have had NO problem getting the few needed NH parts for the 1920 but don't know if that's better or worse now for the new stuff.
There will likely be more questions but that's all I've thought about so far. Feel free to ask me any I haven't thought about.
Thanks much for your time,
Snuffy
/ downsizing-what's out there and more ?'s #3
Welcome.
Shibaura still manufactures a couple New Holland models, but for the most part, NH, actually now "C-NH" (Case-NH) is owned by fiat, and buys most of their 50 HP & under tractors from LS-Mtron. Subsequently, LS-Mtron also now retails the very same tractors they make for C-NH here under their own badging.
The only remaining Shibaura builds are the Boomer SuperSuite CVT cab tractors, i.e. the 3050.
There are some NH purists who believe that the Shibaura builds were better tractors than the LS builds. However, the LS tractors are proving to be very reliable and offer a nice variety of models.
So, if you are wanting to stay with blue, you can either buy an LS from NH, badged as NH ... , or you could buy an LS directly and save thousands.
Lots of great offerings out there from all the brands now. For 1.5 acres, you might be better off with a SCUT (sub compact utility tractor) which is basically a half size up from a garden tractor / riding mower, but built like a real tractor. The loaders will still lift a decent amount, probably similar to the capabilities of your current loader. They also have 3pt so you can still do tractor work with them. They also have MMM options (mid mount mower) and from all accounts I've seen here, they have a nice cut quality. Most of them offer easy attach/detach MMM's. A MMM would be nicer to cut with than a RFM (rear finish mower).
I don't recall all the model classifications from all the brands in the SCUT sizes ... But here's a few I do remember:
LS J series, I believe J2023 (NH sells these as Boomer 20)
Massey GC series, I believe 1710 or 2300.
Mahindra Max, 22 or 25.
Kubota BX series
JD One series.
Again my model numbers might be off so someone please correct me if I'm wrong. Also, there are other offerings from other brands, I just can't recall them at this time.
/ downsizing-what's out there and more ?'s #4
Snuffy
JD 2025r,Kioti CK or Kubota BX series tractors.
/ downsizing-what's out there and more ?'s #5
Although most tractor dealers will take your old tractor in on trade just like auto dealers, you would be better off selling it yourself. A tractor in good working order should be relatively easy to sell. Search the web for your tractor model to see what they are selling for and/or ask the dealer what he would sell it for and then put an ad on Craig's List.
/ downsizing-what's out there and more ?'s #6
I suggest you keep the tractor and consider selling the rear mount mower. Then look for a new dedicated four wheel steer mowing tractor or zero turn. You can use your NH with its higher weight and better traction for the other jobs while mowing the lawn with a lighter rig. This would be a better and cheaper way to go imo.
/ downsizing-what's out there and more ?'s #7
I agree, especially if inherit means it has a special meaning to you. Once it's gone you may have remorse. Anything much smaller is a lot more limited for loader use.
/ downsizing-what's out there and more ?'s #8
I agree also, get a nice zero turn for mowing and keep the tractor. Zero turns are great mowers.
/ downsizing-what's out there and more ?'s #9
Having sold two Kubotas, and bought 3, I would suggest selling it yourself. Make sure it is maintained, CLEAN, and fix any broken or missing items. A well cared for tractor sells easily. A beat, stored outdoors tractor seems to take a lot longer, in general, to sell.
I like Kubotas, but no doubt other brands are equally well designed and made. After getting a L3130, which, at 5700 lbs total weight proved too big and heavy for our needs (well, for plowing snow, it was great, but for driving around the property to lift things and drill fence post holes, too heavy) we settled on a L3400- about 2000 lbs less, but a little smaller, and most importantly, nice fat turf tires, and hopefully it will be a keeper. The first was a 1988 B8200, which was a great little machine, albeit low powered, but it had a gear tranny, which was a problem if my wife wanted to drive it, plus I craved a newer tractor.
Would like to say I got my first offer recently but was rather disappointed. My father knows this guy (he and Dad have bought and sold stuff back and forth in the past and this guy dabbles in buying and selling tractors) who might be interested in it and gave me his number, I called him and told him all the details along with my asking price ($12,900). He seemed to be quite interested as he knows the machine from when my uncle bought it new and knows most of it's history. Said he wanted to see it and as I had to be out of town that day I gave him directions and told him where to find the key. Later on that day wife calls me whilst I'm on the road and says he called back telling her if I wanted more than $10K he just wasn't very interested...
Has the small tractor market tanked or what? I know at that price there wasn't 'much meat left on the bone' for him but I was willing to entertain an offer-just not one quite that low.
So I reckon I'll wash 'er up and maybe wax it, then set it out in the front yard with a sign on it and see what happens. Lots of wealthy retirees around here so I really don't expect it will sit very long.
Thanks much for the response and advice. I'll keep y'all posted.
Hoo boy-now that was quick enough to make yer head spin!
I freely admit I been more than lazy re: selling my 1920 over the last couple months. Finally last week, I got a wild hair, got busy and cleaned 'er up real good with the pressure washer. Had to dig up a For Sale sign and yesterday stuck it out in the front yard...
And on the second day, it is GONE!
Didn't think it would take long but jeez, that was quick! I sure am gonna miss that tractor(sniff!)
But I reckon the local LS dealer will do his utmost to help me to get over it-LOL!
/ downsizing-what's out there and more ?'s #12
Not sure that you will get near your asking price (I'm not familiar with NH tractor re-sales), but bear in mind the guy that looked at the tractor sounds like he is essentially a dealer. In short, he's looking to buy low and sell high for profit, so you would probably do best to advertise it and start at your asking price. If you get no lookers, you can always drop the price. Check the same model tractor at TractorHouse.com, there should be some of the same model there and you can get an idea of what your model is going for. Good luck.
/ downsizing-what's out there and more ?'s #13
You're a little late, he already sold it
/ downsizing-what's out there and more ?'s #14
By the way, OP...
I just recently learned that Daedong (Kioti) bought the rights and tooling from Shibaura, for Shibaura's SCUT's. So, the Kioti SCUT's (CS models) are Daedong built Shibaura SCUT's. And ironically, now the NH sold SCUT's are actually built by LS.
Tangled web.
But, if you still want something close to a Shibaura, and a SCUT will handle your work, you might want to checkout a Kioti.
Actually stopped by the local NH/JD dealer last Sunday(they were closed-I wanted it that way) mainly to peruse the small NH line to see how LS builds 'em and there were none to be had. He only had about 3 NHs total and all were far too large for my needs.
Plenty of JDs and Kubotas (tho not very many SCUTs of either brand) Then I got my hopes up as I stumbled up on a used Kubota backhoe package that looked to be perfect then I saw a sold banner tied to the steering wheel. Ah, the story of my life...
Oh well, I'm not in that big of a hurry. Am seeing good things re: TYM and Mahindra -might have to add them to the go-look-at list, just wish the TYM dealer was closer. My cousin has an older, larger Mahindra -he swears by it. Also found a Branson dealer and want to look at Kioti if I can before making any decision.
Now I keep finding little things around here I should have done before letting mine go...GRRR!!
2015 Bobcat E42 (A64126)
2015 Bobcat E42...
6R RIPPER BEDDER (A64276)
6R RIPPER BEDDER...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
