So what would happen if PT Folded
   / So what would happen if PT Folded #21
Then it would not be an authentic PT. This would reduce it's value at the Power Trac shows.
I better go dig the original head lights out of the trash in case I want to show it then.... :D
   / So what would happen if PT Folded #22
I made adapters for those wheels I bought. They have been working nicely so far. Used the PT with the swinging minihoe today to chunk some logs for firewood. The studded chains are nice on ice.
And yes, it is my understanding that PT makes their own cylinders. I rebuilt my steering wheel cylinders a couple of years ago. They were letting fluid leak through which was causing my loader to catastrophically drop. This Spring, I will likely rebuild the rest.
Ken
   / So what would happen if PT Folded #23
I call PT the other day, and talked to Keith in parts, and he said PT makes their own cyl.
   / So what would happen if PT Folded #24
BTW, the 5x4.5" bolt pattern is the same as used on Ford and Chrysler cars (not trucks) so that might be an option also.
Most Jeeps are that pattern also which would give you better size options
   / So what would happen if PT Folded #25
I have thought of trying some of these automotive wheels but aren't the lug bolt holes a larger diameter?
By the way. You guys failed to talk me out of buying a new tractor. Ordered it yesterday. Terry and Eddy say they've made several upgrades since my old 2003 model.
Sent from my iPhone using TractorByNet
   / So what would happen if PT Folded #26
They use a 1/2" stud, not sure about the hub hole size though -- perhaps not an issue if the PT has a flat hub
   / So what would happen if PT Folded #27
Congratulations!!! :thumbsup:
   / So what would happen if PT Folded #28
Awesome! Take a bunch of pictures before you get it dirty. Will be interesting to compare to your 2003 model.
So what did you buy? Heck, start a new thread while you are at it.
   / So what would happen if PT Folded #30
CONGRATULATIONS!!!
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 Deere 323E (A53317)
2018 Deere 323E...
