Just bought a new tractor, my comments on tractors Sub Compact thru Utility.
/ Just bought a new tractor, my comments on tractors Sub Compact thru Utility. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
I have spent a lot of hours on tractor seats/ heavy equipment, so I do my research when I buy, a new/replacement machine.
Tractor purchase is something I do not do often; thank God for that, as I can not afford it.
After doing my research, and buying the best fit for my need, I thought I share my general observations.
I would also like to see what other people would like to see brought to market for tractors.
Tractors Like cars will be getting smarter. Big Ag. is already taking advantage of this, so their will be trickle down to the smaller machines. That whole topic is beyond the scope of this post.
So that leaves Cup holders.
Seriously, Ergonomics must not be a foremost thought in the design of ractors.
Comfort, Reach location of controls etc. What are some manufactures thinking.
What about supplying Pre Wired and labeled wiring harness extra tie in points and Spots to mount extra lights and tool Boxes.
Don't the dealers want to sell Accessories? I'd pay more for well integrated stuff, designed an built with quality that integrates with the tractor.
Now regarding the tractors themselves.
Transmissions.
Gear vs. Hydro is not the only option. Kubota has a good thing with the GST and their 3 Speed two range hydro, so you have essential six ranges. What about a smart GST type transmission, Throttle and gear selection based on load, forward speed based on a foot "drive by wire throttle rheostat"
European tractors seem to have the edge in the use of CVT.
The tipping point on the decision to purchase Mahindra Max 28 beside capabilities and price was the 8 speeds forward and reverse. Aside from Kubota, there are no other manufactures offering a anything beside a 3 X 2 Gear or 2 Speed hydro in the small compact segment.
I can understand offering a light minimum feature tractor for general field mowing and light chores as an economy entry, but it also in each size range a workhorse model that has lots of features built on s different frame if need be should be part of the lineup.
Generally tractors have way to small a front tire and front axle/ power steering for serious loader work.
Not to pick on LS, they make a nice tractor, but as a typical example rear to front size difference like this is too much:
Their G Series uses:
Ag Front/Rear: 7 14 / 11.2 24
Industrial Front/Rear: 25 x 8.5 14 / 43 x 16 20
Turf Front/Rear: 25 x 8.5 14/ 41 x 14 20
I suggest for instance:
Ag Front/Rear: 9.5 - 16/ 11.2 24
Industrial Front/Rear: 10 x 16.5 / 43 x 16 20
Turf Front/Rear: 28 x 8.5 15/ 41 x 14 20
Note that the LS R series tractor has less of a difference between front and rear tire size, and a noticeable difference in FEL capacity, without that much of an increase in machine size.
On my new Max 28 XL, I would have appreciated having 25 x 8.5-14 front tires in place of 23x8.5-12, for better floatation & traction.
All Loaders seriously begs for a 4 Link Pivot at the bucket pivot and that the bucket attachment be a standard Skid Steer QA system for versatility and articulation.
Loader curl strength / lifting capacity should be increased, so you can use the curl to break out of a pile. I recognize lift ability is limited by safety concerns but too many tractors have loaders so weak they don稚 even need ballast.
Why not offer loaders with pressures set low from the factory, with anti tampering hardware on the reliefs, such that only a dealer can change, if and only if the tractor is sold with proper ballast. That puts safety responsibilities on the owner/operator while allowing the machine to use its full capabilities.
Regarding PTO HP and 3Pt hitch capacity, hydraulics & remotes, I am suspired how much difference in specs exist for a given size of tractor the amongst the offerings.
The post is already too long to get into back hoes. Needless to say there are some scary and useless ones out there and some that are thought out and well matched to the machine.
Manufactures need to realize that a poorly executed TLB on a otherwise nice base tractor is a lost sale.
/ Just bought a new tractor, my comments on tractors Sub Compact thru Utility. #2
What made you go for Mahindra, versus LS?
I think ergonomics on today's tractors is of prime importance. Something basic like getting onto the seat still could be easy for only a good contorsionist!
I agree about what you say regarding front and rear tire ratios. The bigger the tire, the easier your drive in the woods and where you need to cross ditches, go threw ruts etc... It all depends the use of it the end. Choices are more than plentyfull for every need.
Bring out the pictures of your new mount!!:D
/ Just bought a new tractor, my comments on tractors Sub Compact thru Utility. #3
I am so glad I was able to buy new before they ruined yet something else with their smart technology!
LS and Koiti make a good tractor but I wanted gear or alt least 3 speed Hydro but not a gear like my Old B7200D. Stuff has not changed much in 32 years.
I wonder if my review is up in the review section.
Being Mitsubishi built was also a plus.
I think the best tractor out their in this size is the Kubota B3350 (Getting aweful big for a B series)
Compact Tractors | B50 Series | Kubota Tractor Corporation
https://www.kubota.com/AboutKubota/KubotaVideos.aspx#videoPlayerHolder
If I had to have just one tractor, now my place is established and if I was scaling down, The B3350 or the smallest Grand L would be it.
Just too much money to swing, unless I start selling off stuff.
I've got a few photo shots in the attachment and Mahindra forums
/ Just bought a new tractor, my comments on tractors Sub Compact thru Utility. #5
Kioti has 3 speed hydros. Also AWESOME loader lift, 2750+/- # in the DK-40 series.
/ Just bought a new tractor, my comments on tractors Sub Compact thru Utility. #6
Transmissions.
All Loaders seriously begs for a 4 Link QA system at the bucket for versatility and articulation.
Regarding PTO and #Pt hitch capacity, hydraulics & remotes, I am suspired how much for a give size of tractor the difference amongst the offerings.
I don't understand a lot of what you posted...
What is this 3x2 gear transmission you are speaking of? What is a 4 link QA?
Most loaders are set low (relief pressure) from the factory. Many Kubota owners report that they have tested their hydraulics to be low, and have adjusted with appropriate shims from Kubota. My Massey, which already had an impressive loader, was just tested and found to be low, was 6% under spec. I adjusted it to spec and gained 17% lift strength.
Putting the safety/responsibility on owners is reasonable, until you realize that many owners aren't reasonable, and might not be safe with the added capabilities. And regardless, in today's sue happy world, they need to be more concerned with liability than performance.
I have no idea what this means ... ?
Also CVT is available with the NH BOOMER cab series, but never really gained much of a following. The theory sounds like it could have merit, but in application hydro seems to be king.
Don't forget, all of these tractors are built to a price point. If they put the full gamut of tech and capabilities you refer to in AG tractors, a tractor like your max SCUT would run $35k, and mine would be $70k.
Kioti does in the DK's. 2 speed HST and 6 x 2 Gear in the small CK2510, And I was looking for small CUT. Kioti was more $+1K money than my deal on the Max 28.
Re: Comments on my sentence stucture.
Comments on my sentence structure noted. Please see my comments within your quote
This should be clearer, sorry.
3 x 2 gear means 3 forward speeds, and 1 reverse on the shift pattern with a 2 range transfer case. (i.e., 6 Speeds forward, 2 reverse.)
I was not aware of that.
So adding a bucket linkage like a Kioti CK 2510 to a small CUT and next size up tires to front would double the price? Steel is relatively inexpensive. That is why a SCUT prices so close to a mid size CUT.
do you think a few additions to the wiring harness, and better seat would change costs significantly.
Yes, there would need to be redesign and tooling, to best amortize the cost those changes would need to be done during a major model upgrade.
PS your Massey 1648 has the QA loader and a 4 Link articulation at the bucket I speak of.
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
1996 International Water Truck with a Caterpillar Engine (A61307)
1996 International...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
