JD 3720 Cold Start Issues
/ JD 3720 Cold Start Issues #1
jloven
Marshall, NC
2013 John Deere 4720, 2014 New Holland T5.115, 2017 JD 4066R cab
All of the sudden I can't seem to get our 3720 to crank. We have plugged the block heater in for several hours (overnight) and temps are in the low 20's now but when I turn the switch, nothing happens. The glow plug indicator comes on and stays on along with the warning light (! light). You can hear the click-click-click but the glow light never goes out (over an hour of waiting presently). Have the battery jumped and getting 14.8 volts at the terminals. Would it be that the glow plugs are not heating or a sensor somewhere is not closing in the starting circuit or something else?
/ JD 3720 Cold Start Issues #2
"Will not crank".. To me that means the starter doesn't turn the engine over i.e. crank.
To some, it might mean the starter turns the engine over, and over, but the engine will not fire and start.
Sounds like you may have a bad battery issue, or poor terminal connections that a cleaning might fix.
Will not crank in this case means there is no closure of the starter solenoid, nothing happens when the switch is turned fully clockwise. What is preventing the switch to engage the starter solenoid is the question. Not sure what sensor(s) are involved or if it could be the glow plugs are not heating the cylinder to a temperature adequate to allow the starter to engage??? We have the battery jumped and have 14.8 volts on the fuse buss, eliminating the battery and terminal problem. Called the closest dealer, and all he could suggest is to roll it out in the sun....I think its something electronically is not allowing the starter to be engaged. Also, the dash lights are not coming on and off like they typically do.
/ JD 3720 Cold Start Issues #4
If this is the original JD "Strongbox" battery than I'd bet that's your problem. There are tons of threads in this forum about them...yes I know you jumped it and have the correct voltage but maybe it goes shorted internally when trying to deliver the proper current.
/ JD 3720 Cold Start Issues #6
It may not be the cold. There is a starter relay (not sure if that is the official name) that will sometimes cause similar indications. Sitting in the seat directly between your knees on the console is an access door that is clipped closed. Open it and you will see three small square black relay modules, blow all the dirt from around the relays, if you haven't done this recently it is most likely full of dust. Then, I believe it is the far right relay, but it may be the center, pull the relay and clean the contacts and reinsert. See if it starts. I had do this allot until I cleaned the contacts with a fluid.
Good Luck
/ JD 3720 Cold Start Issues #7
20 degrees is not cold enough to keep your tractor from starting. If it were cold enough to give you trouble, the motor would still turn over but might not fire off as soon as you expected. I agree with the others; you probably (hopefully only) have a battery issue.
Also, I'm not sure how your pre-heater functions; the one that operates with the ignition key. We have three Deere's that all function differently; one works when the key is set to on and shuts off on its own after a few seconds. Sometimes we have to cycle it several times before the motor will fire off in the cold weather. Another functions when you push the key in and has an indicator light that glows while it's on and the third works that way but without an indicator light. Each tractor seems to behave differently in the extreme cold.
All this offered for whatever it's worth...
/ JD 3720 Cold Start Issues #8
The only way to eliminate the battery is to remove it and place it 50 feet away so that you will not be tempted to jump start the tractor. Try a known good battery, it will most likely crank. I know my 3320 did when I had some very odd issues trying to start the machine years back.
I checked the starter relay this afternoon by swapping with the other two identical relays but did not seem to make any difference. Also checked the 30 amp fuse and it was good. Battery is less than 1 year old and we jumped it straight to the starter and it turned it over just fine, just wouldn't start probably due to the fuel relay not opening. In any event I guess I will load it up tomorrow and take it in for repair. Without the schematic it's impossible to know what is in series with the starting circuit. I am still betting it's some sensor or switch that is not working properly.
/ JD 3720 Cold Start Issues #10
Hope they find the problem easily.
For future problems, might be worth the $$ to get a copy of the tech service manual as it will be a good source for trouble shooting. Less than an hours time at the dealer shop.
Thanks for the update on the battery being a year old.
/ JD 3720 Cold Start Issues #11
Wonder if your key switch could be a problem?
Also agree on the manual.
Possibly one of the safety switches not letting it crank too.
It's at the dealer and they thought they can get to it monday. Will post what they find when I go pick it up.
/ JD 3720 Cold Start Issues #13
Hopefully it's not something as simple as the PTO switch being ON. I've had similar experience with my 3720 and found the PTO switch only needed pushed in to the OFF position for the engine to start.
Update: I picked the 3720 up from the dealer this morning. Only took an hour or so at the shop and its back to starting perfectly. That's the good news. The puzzling part is that the mechanic reported that a 10 amp fuse was missing from the fuse box and that was the reason it was showing the Error Code 57 and would not start??
I looked at the fuse box and he stuck a 10 amp fuse in the F2 slot. Amazingly enough is when I look at the manual, it shows this to be blank for a non-cab tractor! I didn't know this at the time or I would have questioned them about it. In any event, the tractor starts, the error codes have been cleared, and I have a $241 ten amp fuse installed!!
On one hand if this is truly the solution, I could kick myself for not sticking a 50 cent fuse in the panel, but on the other hand, how could I now based on the info the manual provided??
/ JD 3720 Cold Start Issues #15
Maybe pull that fuse out and see if it'll still crank? That'll confirm whether the manual is right or the mechanic was.
/ JD 3720 Cold Start Issues #16
Manuals can have errors in them... and do.
Mechanics can have brain farts too. :D
As I suspected, tractor would not start after I got it back home. Called the dealer and he came out and looked again. Not sure what it might be. Could be in the instrument panel he thinks...I hate to pay them another large sum to change the panel out plus $600 for a panel that seems to work. Looks like a short to me in a wire somewhere.
/ JD 3720 Cold Start Issues #18
Have you triple checked all the safety switches ? I know you may have done so but this sounds like something you could handle....as you say, hate to spend more $$$ green on the green.
.keep us posted
Latest update: pulled the tractor into a 75 degree shop and after sitting three hours, starts and runs fine. Eliminates Wiring issues, could it be the dash? Going to remove instrument panel and leave outside overnight then reinstall and see what happens.
/ JD 3720 Cold Start Issues #20
jl
You don't have your location in your bio (that would help !! ) so we don't relate well to what country or area you are dealing with, as far as temp, etc.
A 75 deg shop is way too hot for me, even if sitting around for long periods of time. Let alone, having to move around... I'd be shedding a lot of clothes. :D
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
John Deere 6130M (A64126)
John Deere 6130M...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
