need help troubleshooting BX-24 Stall
/ need help troubleshooting BX-24 Stall #1
timalabim
Stalls over 2000 RPM. Will start and idle if kept under 2K.
Replaced both fuel filters 2x, drained tank, cleaned, blew out lines.
new fuel, treated fuel. Fuel Pump makes clicks like it's working.
Any suggestions?
/ need help troubleshooting BX-24 Stall #2
Have you checked your air filter.
yes air filter replaced too.
/ need help troubleshooting BX-24 Stall #4
Fuel supply rate issue. Pump going bad, water separator clogged, fuel screen blocked, wax in fuel from cold weather.
/ need help troubleshooting BX-24 Stall #5
Tank vent plugged.
/ need help troubleshooting BX-24 Stall #6
you bled out the fuel lines as well?
/ need help troubleshooting BX-24 Stall #8
I'd take your rear filter off and check it again. You should be able to blow air through it real easy. If not its plugged again. I know you already changed it but they are crap filters, way to small.
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
Case IH 5100 (A64119)
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
2011 John Deere 1200H Bunker Rake (A66734)
2011 John Deere...
GROVE RT520 ROUGH TERRAIN CRANE (A67714)
GROVE RT520 ROUGH...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
