need help troubleshooting BX-24 Stall
   / need help troubleshooting BX-24 Stall #1
timalabim
Stalls over 2000 RPM. Will start and idle if kept under 2K.
Replaced both fuel filters 2x, drained tank, cleaned, blew out lines.
new fuel, treated fuel. Fuel Pump makes clicks like it's working.
Any suggestions?
   / need help troubleshooting BX-24 Stall #2
Have you checked your air filter.
yes air filter replaced too.
   / need help troubleshooting BX-24 Stall #4
Fuel supply rate issue. Pump going bad, water separator clogged, fuel screen blocked, wax in fuel from cold weather.
   / need help troubleshooting BX-24 Stall #5
Tank vent plugged.
   / need help troubleshooting BX-24 Stall #6
you bled out the fuel lines as well?
   / need help troubleshooting BX-24 Stall #8
I'd take your rear filter off and check it again. You should be able to blow air through it real easy. If not its plugged again. I know you already changed it but they are crap filters, way to small.
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
J and L Cargo Express Shadowmaster Enclosed Trailer (A51039)
J and L Cargo...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
SERVICE BODY BED W/CRANE (A50854)
SERVICE BODY BED...
