Loader CK35 Loader Problem
/ CK35 Loader Problem #41
Please help me to understand. When back-grading, say the bucket is level, no problem. If you curl the bucket as to dump the bucket, and the front wheels come off the ground, and back grade, It's this position that stresses out the linkage. Is this correct?
/ CK35 Loader Problem #42
Correct. You don't even need the front wheels off the ground. All that's needed is to come against something in the ground that won't move or even the ground it's self while back blading with the bucket curled most of the way down. It's not only small tractors that have this problem. It happens to large tractors too. And the color of the tractor doesn't matter either. They are all vulnerable.
/ CK35 Loader Problem #43
Well I guess I've been guilty and lucky. I always backgrade with the loader blade.
/ CK35 Loader Problem #44
Chuck you would a lot better off if the loader was in float when back-dragging. That way the loader arms are free to "float" up when it hits something immovable. The weight of the loader and bucket will smooth out material like gravel and dirt. You will do a lot better job, and a lot less strain on the parts. Also don't point the loader bucket down or even any where 90 degrees down. Sure you can give the lip of the bucket some down angle to accumulate material under the bucket to be distributed into the low spots, after all that is the whole idea when smoothing, but trying to drag back material in a locked cylinder and vertical or even reverse angle position is what caused this breakage of parts.
/ CK35 Loader Problem #45
If you backgrade in float position you will not have a problem. I have hit hidden rocks and even low stumps I did not see, and it causes no problems, the bucket and arms just slide over the immovable object without any real strain at all.
/ CK35 Loader Problem #46
I think I get it now, the no-go position of the bucket blade is 90*. Just a back-tilt is o.k.
/ CK35 Loader Problem #47
90 or more is the worst, use float and less than 90.
/ CK35 Loader Problem #48
There is a particular tractor that is immune to this potential damaging effect of aggressive back dragging where the hydraulic cylinders are near full extension causing the bucket edge to be 90* or better (angled back toward the tractor). That tractor would be.........a tractor without a front end loader :p :eek:. (Me bad :ashamed:) However, I believe the vast majority of tractor owners would definitely prefer a tractor with a front end loader for the many other benefits it allows. I try to think of the front loader as a wheel barrel with hydraulics arms, not a bull dozer. There are 3 point attachments that are much better at ground engaging activities.
/ CK35 Loader Problem #49
This post will get people talking. A couple of years ago I turned my curl brackets on my DK45 into pretzels. The brackets are made out of 3/8" plate with the ends doubled to provide pin bearing surface. Local dealer a couple hours away wanted about $85/ea plus shipping and figured a couple weeks delivery. I had a plate shop cut new ones out of 3/4" plate and a machine shop bore the pin holes and threaded pin retainer holes. My cost was about $55/ea and I was down for less than 2 days. At the time down time was critical. Yes I greatly strengthened the curl function of the loader. Yes I took it easy for a while looking for the next weak spot. It has now been a couple of years and no problems. WP_000186.jpgWP_000174.jpgWP_000175.jpg
/ CK35 Loader Problem #50
I noticed my dealer had four curl bracket hanging on his display panel when I was last in, so it must not be that uncommon to bend them.
/ CK35 Loader Problem #51
This post will get people talking. A couple of years ago I turned my curl brackets on my DK45 into pretzels. The brackets are made out of 3/8" plate with the ends doubled to provide pin bearing surface. Local dealer a couple hours away wanted about $85/ea plus shipping and figured a couple weeks delivery. I had a plate shop cut new ones out of 3/4" plate and a machine shop bore the pin holes and threaded pin retainer holes. My cost was about $55/ea and I was down for less than 2 days. At the time down time was critical. Yes I greatly strengthened the curl function of the loader. Yes I took it easy for a while looking for the next weak spot. It has now been a couple of years and no problems.View attachment 405706View attachment 405707View attachment 405708
You're livin' on the edge of glory if you're aggressively back dragging. If damage does occur in the future please share with us, so we can all learn from your experience.
My concern is, it could be a much more expensive repair. As long as your budget can handle the expense....forge on.
/ CK35 Loader Problem #52
I always put the loader into float and and some rocks in the bucket for weight.
/ CK35 Loader Problem #53
You know I was thinking about all of this and I am going to reverse my position completely on the op's original pictures. I don't think these brackets would break from back blading. I think the cylinders would bend instead. This break is caused by having the bucket curled all the way down (or forward) and then pushing forward into something. Your thought's?
PMS
I said I was backdragging with the bucket blade curled all the way under toward the tractor; why is this so difficult to comprehend?
I measured and found that the link BELOW the half moons (as some have termed them) is 50% thicker material. Half moons=6 mm, lower link=9mm.
/ CK35 Loader Problem #55
This post will get people talking. A couple of years ago I turned my curl brackets on my DK45 into pretzels. The brackets are made out of 3/8" plate with the ends doubled to provide pin bearing surface. Local dealer a couple hours away wanted about $85/ea plus shipping and figured a couple weeks delivery. I had a plate shop cut new ones out of 3/4" plate and a machine shop bore the pin holes and threaded pin retainer holes. My cost was about $55/ea and I was down for less than 2 days. At the time down time was critical. Yes I greatly strengthened the curl function of the loader. Yes I took it easy for a while looking for the next weak spot. It has now been a couple of years and no problems.<img src="http://www.tractorbynet.com/forums/files/kioti-owning-operating/405706-ck35-loader-problem-wp_000186-jpg"/><img src="http://www.tractorbynet.com/forums/files/kioti-owning-operating/405707-ck35-loader-problem-wp_000174-jpg"/><img src="http://www.tractorbynet.com/forums/files/kioti-owning-operating/405708-ck35-loader-problem-wp_000175-jpg"/>
I think you just made your curl cylinders the weak point in your FEL but, it's your money so carry on. I would make sure that your dealer keeps spares on the shelf for you.
Back dragging with the bucket even close to 90 degrees makes no sense? If you want to dig with bucket, as opposed to smoothing which is the reason for back dragging, why not turn around and do it in forward? If you were going forward, with bucket at same angle, you would create same damage if you hit something immovable.
Sent from my iPad using TractorByNet
/ CK35 Loader Problem #56
PMS
It's not the comprehending that is difficult. It's just the visualising in my mind how this happened. I think I got it now. It's the fact that the pieces are in a half moon that takes the strength out of them.
/ CK35 Loader Problem #57
That's quite the difference in metal thickness/strength on your curl brackets.
Judging by your pictures of the bent ones I afraid I would have done the same thing.
3/4" plate may have been a little extreme, but I would have had them made up stronger than the OEM brackets
/ CK35 Loader Problem #58
Here's what I don't 'get'. How did you manage to pretzel the 1/2 moons on a DK-45 series? That setup is so much stronger than what my DK-35 had, and the 1/2 moon brackets are much beefier than those on the CK series? And how did you avoid cylinder damage and just destroy the curl brackets? Spill!:)
/ CK35 Loader Problem #59
Not that it makes any real difference but, both of those broken brackets look like they had started to break earlier. There looks to be rust on the edge of the cracks, which usually means it was cracked there long enough to build a little rust before it finished breaking.
/ CK35 Loader Problem #60
Forces crack paint, atmospheric moisture enters equation, metal begins process of rusting, further extreme forces are applied, twist, bend, snap. Spend money.:confused3:
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
(4) RAM 2000 LB TRAILER JACKS (A64280)
(4) RAM 2000 LB...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
LOOK! (A63111)
LOOK! (A63111)
2002 Freightliner Allegro Bus Class A Motorhome (A61574)
2002 Freightliner...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A61572)
2007 JLG 600HJ...
