Scrambler82
Be careful where you pull your power from.
Some OEM Connectors and Circuits are not setup for higher amperage and yes I understand the lower amperage draw but if you add enough LED Lighting you can over power an OEM Circuit very easily.
It is far better and sometimes safer (overheated wiring) to add a new fused circuit setup to handle the new circuit amperage.
Just talking out loud, I will get off the box now.
