Loader CK35 Loader Problem
/ CK35 Loader Problem #1
skipples
Somis, CA
Kioti CK35 HST, Kioti DK5310SE HST
The pivot brackets near the bucket of the KL130 loader on my CK35 HST snapped today. This thing only has about 95 hrs, June 2013 purchase.
Anyone else have this problem? Are there any beefier replacements available? It looks like they're easy to replace if I can find some. Thanks..... I would appreciate ANY insight into this issure, especially suggestions as to methods to avoid repeat problems.
Here's the parts involved from Michigan Iron and Equipment website:
3 CK06-0200R Boom Linkage Assembly RH, Outer
4 CK06-0200L Boom Linkage Assembly LH, Outer
5 CK06-0100R Boom Linkage Assembly RH, Inner
6 CK06-0100L Boom Linkage Assembly LH, Inner
OK
/ CK35 Loader Problem #4
First I have ever heard of this happening. What were you doing when it broke. Would love to see some pics
/ CK35 Loader Problem #5
Just saw the pictures . Wow would not have expected that
/ CK35 Loader Problem #6
I am dying to know how that happened. I have not heard of this before.
/ CK35 Loader Problem #7
Back dragging with bucket curled too far forward? Bottom of bucket way beyond 90 degrees with ground, I.e., blade behind pivot point and hit something immovable? Just a guess?
The links look to have failed in tension not compression.
/ CK35 Loader Problem #8
I'm wondering what the hydraulic pressures (psi) were set at. Is the pressure relief valve functioning properly.
I'm thinking a relief valve should have kept the loader from that type of damage. (Not my area of expertise)
Need more info on what the task at hand was........
/ CK35 Loader Problem #9
Is that a crack on the main boom in second pic near weld on front?
/ CK35 Loader Problem #11
My guess is you were pushing something with the bucket curled all the way forward and hit something that didn't give. My advice would be not to replace these with something stronger as next time something more expensive will break. Also learn not to use your bucket for blade work in that position. It is only for dumping the bucket.
Yes. Back dragging. Done it a thousand times with no problem but this was in damp clay and it dug in. The links deformed and when the bucket was curled back, they snapped. I noticed that the links were bowed but thought they were formed that way to clear the pins.
My CK 20 never broke; I hope I won't have to baby this one!��
/ CK35 Loader Problem #13
There is no pressure relief with the valve lever in neutral unless you have work port relief, and most don't .
There is a large mechanical ratio from the pins to the tip of the bucket, and that could rip the mount off.
/ CK35 Loader Problem #14
CK35 is a lot more powerful than a CK20. It's a very vulnerable position when the cylinder rods are extended. I have seen much larger machines with bowed cylinder rods from back dragging and the bucket digs in. The quick change bracket also moves the bucket 4 - 5 inches further out from the end of the arms.
Thanks J.J. for clearing that up.
Rick & TB
Yes, when the link deformed it scraped on the boom; it's not a crack. The metal failed in compression because of the way I was using the bucket. First the links bowed out, then snapped. I wasn't watching them but pieced it together in hindsight.
While the CK35 is, of course, much more powerful than the CK20 (that's why I bought it!), I would have expected the construction to be commensurate with the increased power and weight.
/ CK35 Loader Problem #16
Rick & TB
Don't forget that sometimes equipment is designed with a weak link. Replacing these pieces of steel is a lot cheaper than replacing or rebuilding hydraulic cylinders.
That's probably true, Ernie. I guess they could be flattened and welded but I just ordered them from Michigan Iron and Equip for around $200 USD including shipping to me in So California. Lesson learned.
/ CK35 Loader Problem #18
the LS tractors had a lot of problems like that.
Check their forum on this site.
I read them a while ago, seems like the consensus was back dragging was the problem. I can't remember what the final solution(s) were.
/ CK35 Loader Problem #19
Sorry to hear about your problem Skipples, but good info for the rest of us to learn from. Thanks for posting, I hope it's not to costly of repair.
/ CK35 Loader Problem #20
I was fortunate. When I purchased my first tractor a wise old heavy equipment operator advised not to back drag with the cylinders extended to the point where the blade of the bucket is angled back toward the tractor(passed the vertical point). That advice has served me well.
When the need arises to (agressively) back drag, with the blade of the bucket passed vertical, I fight the urge and either hook up the box blade or the 3point grader/leveler made with commercial grade cyclone fencing.
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
Front Tank Bracket (A64126)
Front Tank Bracket...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
