What do you do with your forks?
/ What do you do with your forks? #101
I have a set of Titan forks for my JD 4320 and a set of WR Long forks for the MF 1528. Both sets are built with high quality and hold up to the loader capacities, probably more. My favorite chore is putting a sturdy pallet on them and using to get on the roof, hang Christmas lights and change flood light bulbs. All of that of course with a trusty friend or relative driving.....
/ What do you do with your forks? #102
These are the titan light duty forks. They are rated for #1500 they clamp on and also have slots to chain them on for added bucket protection when doing some serious lifting. Can be installed or taken off in about 1 minute. They have pockets to add stakes for rollback protection as well. I mainly use them for hauling brush and moving logs.
/ What do you do with your forks? #105
Loading a 400+ lb snowmobile. Added a forward guy to keep it level.
I'd like to get some slip-on fork extensions like the dealer has so I could just pick it up. The ones I've found thus far are over $400. Any suggestions?
Anyone have any experience with a set of 3 pt hitch forks by the name of Farmit made by BHS Energy?
Log Skidder, Forklift, & more for 3-point hitch
Thinking about having a set of forks made similar to these that would fit both the 3 pt hitch and the front loader arms.
Building this a bit wider and adding mounts for the loader arms.
These are quite interesting. Detachable forks that remove and mount upright behind the
steel frame-super easy storage and always have them in the field. Chain link
locking brackets top and bottom, skidding and towing. Adding a winch mount too.
For my needs, this may be a very good design.
Your feedback and ideas would be appreciated.
Any idea as to the type of steel I would need, and the cost of materials?
/ What do you do with your forks? #107
I think they look pretty good. Keep in mind if you go wider with the forks they may not go under 3'x3' pallet but most pallets are 42''x48'' or 48''x48.''
/ What do you do with your forks? #108
Get a couple of lengths of rectangular tubing, large enough inside to slip onto the forks (5x3 perhaps), 1/4" wall thickness, long enough to run full length of the existing forks plus whatever you need for added length up to about 4'. Weld a collar of 1/4" x 3 flat bar around the inboard end, drill and tap for a 3/4" or 1" diameter bolt for clamping the tubes to the existing forks at the back end.
The outboard end can be slotted or notched on the sides then partially collapsed and welded up to create a taper.
Pictured is the quick-attach fork setup I made from my B-I-L three years ago. The forks are 2x4x1/4 rect. tube, the outboard ends are tapered as described above. We have moved tree-length logs, blocks of split granite, steel beams and bars, pallets with brick, cement pavers, firewood, other tractor implements...the list goes on and on. Nothing has bent or cracked yet, the forks will handle any load the FEL hydraulics can handle.
/ What do you do with your forks? #109
/ What do you do with your forks? #110
UTCenturion: I would like to see if I can find the containers you mention in this post. I have seen them for sale somewhere, but can't remember where. What are they called so I can search for them? Searched on IBC, but got nothing.
Thanks,
Bob
/ What do you do with your forks? #111
/ What do you do with your forks? #112
Thanks aczlan.
/ What do you do with your forks? #113
DSCF0785.jpgDSCF1308.JPGI use mine for everything. Forks are on at least 95% of operating hours. Built my own from parts collected from forklift service center, and made my own mounts. Added a "The Thumb" grapple that I slid on and off when needed. I just finished another fork attachment and mounted the grapple on it, so now it's a dedicated grapple. Have several tools I've made for the fork attachment: slide-on drawbar for moving wagons and trailers, slide-on tree puller, slide-on chain hook, etc. I'll try attaching a few pics of the first fork attach with grapple.
Do you close up photos of the forks that you made along with the mounts and attachments. Thanks
/ What do you do with your forks? #115
Picked up this Hemlock log today and brought it from the back yard to the wood yard. Had to cut it into pieces to lift it, and even this section flexed the forks. But I can't imagine how I would have moved it otherwise.
/ What do you do with your forks? #116
Lift logs, pallets, gas engines, they rarely come off the tractor. Had a new sad job for them last Friday, had to dig a grave for my old dog.
/ What do you do with your forks? #117
With my Titan forks and this plan is locked in jello, in the morning I will pull off the RR and put my forks on then drive up to the front yard. I have a baby stump and parts to a telephone pole I need to place in a burn pile.
/ What do you do with your forks? #118
Got to try out my forks today. I'm not sure exactly why this is, but there's a substantial gap between the bottom of my QA and the bottom of the plate on the forks. Tell me this is not normal, because they've already popped off while stacking a couple logs.
This pic was taken from the front of the tractor for reference.
/ What do you do with your forks? #119
Can we get a few more pics to orient ?
I don't think that's normal at all. My forks fit like my bucket
/ What do you do with your forks? #120
What brand pallet forks? Is the QA on your FEL full seated in the QA pockets on the forks?
Sent from my iPad using TractorByNet
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2009 Ford F-250 4x4 Crew Cab Pickup Truck (A61568)
2009 Ford F-250...
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
