Goggles?
/ Goggles? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I have a set of goggles but probably a cheaper set and they fog up badly. I think a lot of the problem is if it's so cold I'm wearing goggles I've also have a face mask on that seems to steam them up quicker. Do better goggles actually not steam up? Is there some kind of magic spray you can clean goggles with so they don't steam up? Maybe a different face mask?
/ Goggles? #2
Get a decent set of ski goggles. They will not fog up.
/ Goggles? #3
There are many anti-fog treatments available. Google Anti-fog. We used to use some sold by Bass Pro, unfortunately I cannot remember the name of it. It did work pretty well on my glasses. I used it in conjunction with competitive shooting where we were often out in lousy weather. It was a small jar of a waxy creme you rubbed on your glasses, and then buffed off. Sorry I can't be of more help.
/ Goggles? #4
Try a small, small bit of dish soap. Let it dry and buff it clear. The soap breaks the surface tension of the moisture so it sheets instead of fogging.
/ Goggles? #5
Scuba divers spit on the inside of them and rub it in to keep from fogging over. Try it and report back.
/ Goggles? #6
Make sure they are double lens goggles with an insulating air gap between inner and outer lenses. All good ski goggles are like that, and won't fog. Cheap ski goggles have a single lens, and fog up like crazy, since there is nothing to insulate the humid inner air near your face from the cold outside air. It's very much analogous to double-pane versus single pane windows in a home in cold weather.
I always make sure family members spend a little more $$ on good goggles when we go on ski trips, as vision is one of the most important factors in skiing well and enjoying the day. A crappy pair of goggles can be frustrating and ruin a ski day.
Most good goggles also have a vent you can open/close, which is helpful in warmer weather. The vent is normally covered with foam so that snow can't get inside.
And last but not least, there are different lens colors and tints, and they all have pros and cons. I actually keep 3-4 lenses for my goggles, and will change them based on light conditions. When skiing out west, the light is often very flat, so yellow lenses or high contrast "sensor" lenses are a big help. I imagine the same considerations would apply for snow removal work depending on the time of day and typical lighting in your area.
Anyhow, shop around, I think it's money well spent when picking a good set of winter goggles. They can make vision effects a non-issue.
/ Goggles? #7
/ Goggles? #8
Yep, we do that :) As captain obvious would say tho, do this *before* going outside! Never actually tried outside of scuba tho, so YMMV
+1 on the ski goggles, but quite often I find it just delays the inevitable... When its windy I tend to have a scarf on which sometimes blocks the bottom vents on the goggles, and they then fog up anyways. Mine are super old now too tho so that probably doesn't help. I have 2 pairs, so when i get sick of one fogging up too much I just switch!
DD
/ Goggles? #10
Yes some scuba divers use spit, but baby shampoo is sooooo much more effective.
/ Goggles? #11
Long time skier and snowboarder here.... and goggle enthusiast (borderline goggle problem!) Just back from a holiday ski trip out in Colorado.
I find that if i wear a ski mask, balaclava, or anything else that covers my face that i struggle with fogging. I wear premier models from several manufactures and there's little difference between them when it comes to ventilation. The problem that I have is anything that covers my face directs my breath upwards to escape, this forces moisture up into the lower vents of the goggle. IF i'm moving at a decent clip, it's irrelevant because airflow removes the fog. At slower speeds (like you would experience on a tractor) I have to keep my nose exposed so my breath can escape before hitting the lower vents on the goggs.
Double wall goggs are def the first step to improving your situation. Also, I'm not sure if this is still available, but SCOTT used to make a goggle with an attachable fan that would help evacuate moisture. Might be worth looking into.
If you want to try anti-fog... i find the only one that is worth a dam is called "Cat Crap".
-J
/ Goggles? #12
I use these when mowing, But don't do snow, so don't know about fogging in cold weather.
From a site advertiser: Wolfsnout® OFF ROAD #1 MOTOCROSS/ATV/UTV DUST MASK/FILTER/OFFROAD
One of many threads on it: http://www.tractorbynet.com/forums/owning-operating/311403-dusty-nose-question.html
/ Goggles? #13
I bought this goggle with the 'no fog fan' a few years ago off Amazon. I saved it in my Amazon 'wish list' and monitored the price which varied wildly from one season to the next. I took a leap at a low price point and could not be happier with the purchase. It has a humidity setting that cuts the fan on/off 'on demand' or constant on. You hear a 'whirring' from the fan except when the tractor is running...then you hear the tractor. :laughing:
It's also OTG(fits Over The Glasses),which I needed. My Amazon wish list is not showing it currently however it comes and goes seasonally.
Here's the lnfo from Scotts:
SCOTT Sports - SCOTT Heli OTG Goggle w/ NoFog Fan
/ Goggles? #14
With the recent snow storms this week I had a chance to wear the 'Heli' no fog fan goggles again. Refreshed my memory how much I like these goggles! However the 'Heli' appears to have been removed from the Scott website. The Scott 'Habit' appears to be the updated model.
SCOTT Sports - SCOTT Habit OTG No Fog Fan US Goggle
/ Goggles? #15
OP, in addition to better goggles (could use dirt bike goggles as well) we wear a neoprene half-face mask that has a flap over the nose, deflecting your exhalations down.
Scott makes a big range, $40 or so gets you a good enough adult paair.
SCOTT Sports - Goggles
/ Goggles? #16
Last few storms I used a pair of goggles that have been removed from my "mountain" rotation. They're by Electric, the EG2. They have a spherical lens system that's curved for image correction as well as double walled. I still don't wear anything on my face, I find the beard offers enough protection when combined with a decent jacket/hood.
They work well, even in low light (with amber lens)... no fogging and the field of view is exceptional. They do get pricy, but you can get a simple color from seasons past for a steep discount. Check out sites like Dogfunk.com and Backcountry.com in their clearance section.
-J
/ Goggles? #17
I have two types. One is PanOptic - double lens - foam vented glasses. The other is Smith - double lens - foam vented goggles. Both work very well. I use them when its cold and I ride the Harley. My eyes water a lot just wearing normal sun glasses in the cold. These have foam that hugs tight to your face - prevents cold air from hitting your eyes and vent all moisture out thru the foam.
I've never needed/used either pair when operating the tractor in the winter. However, the goggles will provide better protection from the cold - the foam surrounding the goggles is thicker and the elastic head strap holds them tighter to my face.
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2018 KOMATSU WA270-8 WHEEL LOADER (A65053)
2018 KOMATSU...
