Loader tweak?
/ Loader tweak? #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
fork firewood 001.jpgUsing pallet forks I lift a full pallet of firewood onto my six foot deck. My ck35 will just do it. I lifted a firewood pallet this morning and I swear if I had one extra stick I wouldn't have made it.
Is there anyway to safely goose (tweak ) the loader just a bit to handle this much needed chore?
/ Loader tweak? #2
You might want to post this in the hydraulics forum...
The relief valve can be adjusted to increase the pressure on the loader valve but you will need a pressure gauge to see what the current pressure is and how much you can increase it...
Good Luck...
/ Loader tweak? #3
Several slightly smaller loads.
/ Loader tweak? #4
Stack the heaviest pieces or a larger stack close to the backrest. The more weight further from the backrest the less total weight you'll be able to lift.
/ Loader tweak?
I'll be checking the psi at the loader relief valve. Specs call for 2000psi. Can I up it abit, say to 2500 psi. and still be in the safe zone?, Or should I stay at 2000psi.?
/ Loader tweak? #6
Again I defer to the more experienced guys in the hyd. forum... but IMO...check your hoses for condition and pressure ratings before boosting the pressure too much...2500 sounds like a little much I bumped mine up to about 2250 to make up for weight I've added in a tooth bar and the mounting bar for a thumb grapple...no issues on a '95' model B series Kub....
John Deere 230 Disc Harrow (A66285)
John Deere 230...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
