EH72FI surging
   / EH72FI surging
Looking at the rest of the manual, it is clear that the plug goes into the air cleaner adapter, which is before the throttle body. Small leaks there may let in some unfiltered air, but should not cause surging. My first suspicion would be fuel starvation. Have you replaced the fuel filter?
Yes, I forgot to put in the first post that I replaced the fuel filter (and air filter) early on, right after draining what I thought was the "bad" gas. The reason I ordered a new fuel pump is that it really seems fuel related, and I tried cleaning everything already. Plus, I recall that the pump would "tick tick tick" once the key was put into the ACC position. It still does that, but sounds like it gets quieter after a few seconds, and then eventually stops. I believe there isn't any "smarts" to control whether the fuel pump should turn on/off... It's just always on with the key position since there isn't a fuel pressure "sensor" or similar back to the ECU, etc.
Anyway, hopefully the new fuel pump is the fix. If so, the one good thing that would've come out of all this is finding the chewed plug. That would have done damage for sure over time. Unfortunately, my yard and walkway is torn up from digging the electrical run, and now it's been freezing and snowing, so I'll have to wait for a thaw to get back at it. I have ropes and markers everywhere so no one falls or trips. It's a mess, and my wife is annoyed. :( Whatayagunnado? :jaded:
To add some visuals... here's a pic of the trenches (electrical and drainage) just before the snow and freezing weather came. You can see the PT in the background where I was just about to swap out what I hoped was bad gas.
   / EH72FI surging #15
Yeah! I have pretty much 8" of black dirt on top of 40' of sand at our house. On our property 9 miles away, I have sand dunes, sand, and a little bit of sand. A pocket of gravel 8' deep under 2' of sand, and some sandy muck.... on top of sand! We call any rocks we find dinosaur eggs. :laughing:
   / EH72FI surging
:laughing: Yeah, the only reason you see somewhat normal looking soil is because I trucked in tons and tons of it when putting in my lawn. In my area, you are lucky to have a foot or two of heavy, clay "soil" and rocks, with hard pan, solid clay just underneath it... and I'm talking the type of clay you can form into a shape and put in the oven to make pottery (I actually did this once for my daughter). :rolleyes:
The good news is that my replacement fuel pump arrived. It isn't the OE (that was $90+), but it I think it should work okay. We'll see...:begging:
   / EH72FI surging #17
I think you're on the right track. When the sound of a fuel pump changes, it's generally not a good sign.
   / EH72FI surging #18
KMA,
Did you ever get this sorted? If not, try this stuff: Chevron 65740 Techron. If you can add a little choke to stop the surging, there's a decent change the surging is due to deposits and other problems associated with bad gas and ethanol. I was VERY skeptical this stuff would do anything. However, it was highly recommended online and for a couple bucks what could it hurt. I've since used it to "fix" three different engines. It's not a miracle worker. However, if you have deposit problems, it seems to work good and sure beats a carb rebuild.
marrt
   / EH72FI surging
Hi Marrt,
No, unfortunately I'm still working on it. I'm exchanging emails with Subaru support. I tried an aftermarket pump and it acted the same. This engine is fuel injected, so no carb rebuild (or choke)... but I did take apart and clean the intake manifold and injectors, although they looked fine. I always use Ethanol treatment (either Star Tron or Lucas) in all my small engines, and added a fuel injector cleaner (Rislone) earlier on when replacing what I thought was bad fuel.
Thanks for the feedback.
Kevin
   / EH72FI surging #20
I have a couple more ideas.
Did you check your MAP sensor? They can be cleaned, but you need special cleaners. I have had them go bad, and when they are flaky or bad, they generate lousy engine performance.
The other global item is the fuel regulator that sets the pressure for the ignition system. If it is sticky or worn, it will also be ugly.
Wiring issues? e.g.
  • Bad RPM sensor
  • Bad RPM sensor wiring
  • Bad connector/wiring harness
  • Bad coil (How were your plugs?)
  • Bad spark plug wires (Was there a difference between the plugs?)
Did you check your pulsation damper to see if it is still functional?
Good luck...
All the best,
Peter
2009 John Deere 7330 (A53314)
2009 John Deere...
3Pt PTO Driven Irrigation Traveler (A53316)
3Pt PTO Driven...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
John Deere 261 3pt Finish Mower (A50775)
John Deere 261 3pt...
J&M 250-7 Gravity Wagon (A50775)
J&M 250-7 Gravity...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A55787)
2015 Vermeer SC362...
