Ford f250 5.4
/ Ford f250 5.4 #41
I think a lot of the tans failures are caused by the operator. They don't know how to use a truck with a plow and burn the trans up. Also I see people with loaded trailers backing the truck up a steep grade in 2 or 4 HI instead of 4LO. Then also a lot of people don't service their trans. The 4R100 and E40D were good in their day.
/ Ford f250 5.4 #42
Highest pressure on the seal is reverse. Factory seals were weak and can cut loose a ATF geyser in reverse. Revised seals eliminate this.
My company has become partial to ford vans. We have lots of 5.4s. I have 56,518 miles on this 2012 E350. We miss oil changes often and run these trucks hard and loaded down. They hold up very well. Company ventured away from GM due to everything besides the drivetrain nickel and dimeing them. My last truck was a chevy and it was annoying having door panels fall off, door latch linkages fall apart, and doors fall off. Prior to that I had an e350 with a 300 inline six and c6 transmission. That e350 was an epic dog, but it was a dog that always got you home. The ford and chevy were auctioned off at just shy of 300k miles. Probably still out there somewhere.
/ Ford f250 5.4 #43
+1. I purchased 5 new GM trucks for plowing/personal vehicles and the last 2 that I had were junk. Wheel bearings, transfer cases, steering shaft, water pump, rattles galore, wind noise ect,ect. The list went on and just got tired of it. If these were high mile vehicles I could understand but none were over 60k miles. One took lower ball joints out in 15k miles! I was on a fist name basis with the service advisor that was for sure. CJ
/ Ford f250 5.4 #44
I hope that service advisor got adept at blocking your fist , or did that method prove best method to get service ? :D
/ Ford f250 5.4 #45
Good reason to drop the transfer case into low range any time you are loaded or in a tight spot, as mentioned earlier. Even unloaded I'll drop it in low just for the added control and engine braking. Anytime you can take the strain off the trans/torq converter in thoes situations is going to increase the life of the trans.
/ Ford f250 5.4 #46
What happened to the transfer case? Did the antirattle clip knock a hole in them?
/ Ford f250 5.4 #47
He he! No actually he got to be a good friend[that should have said first!] and he knew what I did for work. So he would ask me what needed to be fixed and did it. Save him time because he almost never had to do diagnostics on the pos's. I picked one truck up and the tech forgot to tighten the front driveshaft [replaced tranny] I knew him also, so I pulled in the back and had him tighten it before anyone found out. CJ
/ Ford f250 5.4 #48
Been there have you?!! Lets see, that one also ate idler arms, until I bought a Moog problem solver and had the tech put that one on. told him to throw the new gm one in the trash. After 4 I got tired of having to take the truck in. That ended up being one of my favorite trucks, drove it another 40k miles to over 100k with only a couple of minor problems. CJ
/ Ford f250 5.4 #49
My neighbor had the hole in the transfer case happen to him. The guy at the dealer in the part dept had never heard of it, he claimed. The replacement had been repaired. My other neighbor saw what happened and got a pump upgrade kit from merchant auto. I know another guy that had the tcase go out of his.
/ Ford f250 5.4 #50
My neighbor also had a hole in his 07 Dmax. It was beyond repair. Truck had 109,000 miles so just out of warranty. He had the fluid changed at 50K and 100K and there was no warning anything was Amis.
I lost a transfer case in my 89 Chevy but can't honestly say what happened. It only had 35,000 miles. When it broke it locked up and sheared the drive shaft off vaulting the trucks rear in the air. Scarry as heck. Luckily I was going under 30 mph.
Chris
/ Ford f250 5.4 #51
Chris
What happened with his is it knocked a whole in it and only leaked fluid while he was driving. He ran it til there was not any fluid in it. That seems to be what happens to most of them.
/ Ford f250 5.4
Just an update on the truck. It's great! The 5.4 pulls the 8500 lb or so load great. Not the quickest, or the most fuel efficient but it's great!
/ Ford f250 5.4 #53
Glad your happy. Don't drive a diesel or V10 if you want to stay that way.
Chris
/ Ford f250 5.4 #54
Good deal!
/ Ford f250 5.4
Chris I have a 7.3 psd. 355,000 miles and runs great. Still like my 5.4
/ Ford f250 5.4 #56
Thanks, for the update. I hope the truck continues to do good for you.
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
PALLET OF JOHN DEERE WEIGHTS (A64278)
PALLET OF JOHN...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A64553)
2025 Hydraulic...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
