Need quick info (continental post hole auger)
/ Need quick info (continental post hole auger) #1
Indygunworks
Indianapolis, IN
1980 Ford 340
Had a deal lined up and the seller backed out. So I started looking again, found these about an hour away from me
3 POINT POST HOLE AUGER
He has agreed to 350 for one of them my choice which.
However I don't want to drive that far for junk. I need to have the holes dug for the porches by the time the inspector comes for the the final house inspection in march and don't want to dig 10 holes by hand. I will also be installing about 1/2 mile of fence, 200 feet of boarded fence, a kids playhouse, and a post frame livestock barn.
I have a ford 340 which is similar to a ford 4000 Independent PTO
Are parts still available for these? Replacement tips? Are they good units?
The man on the phone was older and hard of hearing so not really able to answer any questions.
/ Need quick info (continental post hole auger) #2
Rent?
I don't want to bother working on someone else's timeline.
/ Need quick info (continental post hole auger) #4
I've never seen one, $350 would almost buy a new TSC unit? I've got one about 20 years old, it's drilled lots of holes, but it is just something I got at TSC.
350 wouldn't touch an auger at tsc looking at well over 600 by the time its all said an done.
/ Need quick info (continental post hole auger) #7
I saw a similar one on CL here in Denver recently.
My basic thought was its a very old design that nobody makes anymore. Probably for a good reason. I suspect the modern design is not only less complex (cheaper) but generally works better.
/ Need quick info (continental post hole auger) #8
Important info to know is the size of the output shaft on the gearbox(where the auger hooks to it). Some older units have uncommon sizes, making replacement augers near impossible to find.
Also, if the teeth are worn, can you get replacements? An auger with no downpressure is of little use without good teeth beneath.
Travis
Travis
Would you be able to take a look at this thread, and see if you guys carry replacement augers, or cutting teeth that will fit it?
http://www.tractorbynet.com/forums/attachments/327231-post-hole-auger-what-did.html
/ Need quick info (continental post hole auger) #10
I got the auger off. I tried banging on the bent spiral a few times and it appears that it may develop some cracks when I apply the breaker bar and wrench and bend it back into place. This has me considering a replacement auger from the get go. Will this unit run a 16" auger? It will be used in about as good of soil as you can get. I am also concerned about it having two bolt holes, as most of the newer ones I see only have one.
Here are a few photo's.
The top female end of the auger
The output shaft and two bolt holes
And the size of the output shaft
Here is where I think it will crack. I can probably weld and reinforce it, but if I am going to buy a new auger, I would like to replace it with something larger for telephone poles. that way I don't have two 12 inch augers should I be able to fix this one.
Could I just cut the lower 5 inch's of this thing off and redrill the holes for the tip, and cutting edges?
