Extra Hyd. Valve Kit
/ Extra Hyd. Valve Kit #1
MapleLeafFarmer
Canada
lots including Kubota B's, L's, cat, etc.. over many years
for the Kubota experts out there... I am looking to add a hyd. bucket grapple to my little B2620.
My B2620 came from Kubota with a front bucket and a rear frame mounted Backhoe. Plus some other goodies.
The question I have is about working the cyl. on the bucket grapple.
When I remove the Backhoe I disconnect the 2 hyd. lines from the backhoe and connect them together. The tractor then operates correctly with no backhoe attached. So with the backhoe removed, should I be able to use these lines that would normally run the backhoe when connected to run the cyl on the bucket grapple by adding a valve and hyd. lines to the front of the tractor?
thanks in advance
/ Extra Hyd. Valve Kit #2
thanks in advance
Hi Boakley,
Please check my ealier thread, it may help you
http://www.tractorbynet.com/forums/...ng/183707-extra-hydralic-bx24.html?highlight=
Good luck
/Sam
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2015 John Deere 6130D (A64126)
2015 John Deere...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
