Cold hands
/ Cold hands #21
I use a close fitting goatskin glove like Justin. Then over that I pull on another glove for warmth, lined or unlined. I can get alot of close work done with just the goatskin gloves.
/ Cold hands #22
Cabelas offers a nice selection of liner gloves, link below. I always liner glovesthese under a heavy, gortex outer glove or mit. Keeping your hands dry is very important so I always try to have a spare pair of liner gloves and over gloves close by to swap out if one pair gets wet. The liner gloves have a lot of dexterity so you can keep them on while doing delicate tasks.
http://www.cabelas.com/catalog/sear...=true&Ntk=AllProducts&Ntt=liner+glove&x=0&y=0
/ Cold hands #23
I have bit of wisdom pasted on to me from my days winter mountaineering. It really helps keep the feet and hands warm.
If your feet/hands are cold, put on a hat. If your hands/feet are still cold put on a warmer hat.
I know, "but my head is warm". That is because the body will provide for the brain first, hence the warm head, and the feet and hands last, hence the cold feet/hands. Try it it works.
Gloves? I like layers. Thin liners and then a glove or mitten over that. Really cold, subzero, add a shell over the liner/glove package.
/ Cold hands #24
/ Cold hands #26
Keep your core temperature up and your hand and feet will not get cold. It also takes your body about three days to get used to the cold. It will adapt.
/ Cold hands #27
Also, if you're in the habit of eating a big meal before you go out, you will always feel colder. Drinking water seems to help too.
/ Cold hands #28
Years ago I had a pair of military "mittens" that had a wool liner, but with a separate trigger finger and a leaather gauntlet type shell in the same arrangement. There may also have been a thin silk undermitten--same trigger finger arrangement--but I might have bought that on my own, probably from LL Bean. They were also available in a surplus full mitten/liner combo without the separate finger.
The way the mitten was you could put your hand in with the four fingers in the mitten and trigger finger separate or put all fingers into the mitten portion. It worked wonderful and I used them for decades in a very cold climate. Actually, they were so great I think I still have a nearly new pair tucked in a drawer and not useful in my new warmer climate.
/ Cold hands #29
If your feet/hands are cold, put on a hat. If your hands/feet are still cold put on a warmer hat..
This.
Outdoor Research makes a modernized version of the trigger mitten. But you can buy the milsurp ones of ebay for $25.
/ Cold hands #31
I believe that this is the best piece of advice you can follow. Staying dry is equally important... wet feet will suck the heat right out of you. I carry a sweat suit and sneakers in the truck for the ride home. Also, keeping your house at a cooler temperature is beneficial rather than being accustomed to 80', then going outside.
A few hints from University of Rochester...
Myths and Tips About Dressing for Winter - Online Medical Encyclopedia - University of Rochester Medical Center
/ Cold hands #32
/ Cold hands #33
Well, winter has arrived and as I have grown more senior, I can keep every part of my anatomy warm in sub freezing weather except my hands and fingers.
I would surly welcome any tips on how to remedy the problem and still maintain some semblance of dexterity.
Maybe get a physical to see if there may be deterring problems for cold hands.
/ Cold hands #34
Good point. I have read that cold toes and cold hands are signs of decreased circulation and possibly from hardening of the arteries. See a doc and check it out if you're older.
/ Cold hands #35
I am in the same club.
I learned that what I have is called Renaud's syndrome* and is generally caused by vibration, like old chain saws.
It seems that constant vibration damages the tiny pathways in the extremities (hands, feet) and prevents the circulation of warm blood that keeps them warm.
In my case old chain saws, outboard motors did its number on my hand as neither had anti vibration grips that are now mandatory (OSHA).
Unfortunately in my youth I water skied 7 days a week as an amateur and professional basis.
I also greatly enjoyed winter skiing and both sports literally and constantly vibrated your feet.
On the water it was the waves and ripples, and on snow those old planks could be heard chattering as they sped down hill.
The early metal skis were the worst, you could hear the skier coming they chattered so much.
* Some chain saw owner's manuals explain this quite well.
/ Cold hands #37
I've always heard the same advice-- basically how much heat is lost through one's head in cold weather. Been reading lately that this is a myth.
/ Cold hands #38
I was wondering if anybody else had read that.
Out working in sub-zero cold today, thankfully the wind didn't blow. Once I got acclimated it wasn't that bad.
One thing which I noticed back when I used to wear a wrist watch; that hand always got cold sooner.
/ Cold hands #39
Your body will adapt. It usually takes about three days of working outside before you stop feeling miserable all the time.
