Bought a Ford 3910
/ Bought a Ford 3910 #1
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Little bigger chassis than I was looking for but couldn't resist. Original owner was a sod farmer. Bought it from second owner who took it in trade for some new sod equipment. 3000hrs. Needs rear tires, they are the originals. Otherwise seems solid. Time will tell.
/ Bought a Ford 3910 #2
How much you want for it?
/ Bought a Ford 3910 #3
I'll bet that one is a keeper. Be sure to keep lots of grease in the front axle center trunnions, especially the rear one.
/ Bought a Ford 3910 #4
looks like you did good
I'm a lube freak. Was trying to educate myself on this front axle yesterday. I'm more than a bit confused. The outer hub assemblies are full of oil, I understand that. The axle shafts use a U-joint at the king pins, similar to the front axle in my Super Duty. I understand that. The center section holds oil, I understand that.
What I don't understand is if I cramp the front wheels and look into the area where the axle u-joints are I see gun grease all over everything?? That grease would have to come from greasing the center pivot assembly?? The u-joints appear to be in excellent condition, no slack, etc. Just don't understand where that grease comes from??
If I jack up the front axle, the right side king pins are slightly loose. Not real bad, but there is no slack in the left side. So I'm thinking I should replace the right side. Shouldn't be a big deal to do.
Hopefully someone can clarify the grease thing?? Thanks in advance.
/ Bought a Ford 3910 #7
Very good condition for 3000 hours. I think you done good.
/ Bought a Ford 3910 #9
Grease in the area of the half shaft u-joints is coming from the zerks in the upper & lower steering swivel trunnions (kingpins). Those trunnions should not be loose, there should be a little preload. There may be shims under the trunnion caps that can be removed to snug things up. Make note of the APL number on the front axle tag. That number is the key to getting the correct parts when you need them.
Thanks Rick. I noticed the tag on the front axle. I found a website for CNH parts. Very good info there. I looked at a breakdown of the front axle this morning. There is definitely shims in the trunnion setup. I'll check that out and see if I can just put in a thinner shim or if I have to buy bushings as well.
Spent today working on a weight rack/bumper. I'll post a thread when I get it done.
/ Bought a Ford 3910 #11
Looks in excellent shape for its age. You got a good tractor looks like.
/ Bought a Ford 3910 #12
I agree looks like a nice one and you didn't get hurt on that price either.
/ Bought a Ford 3910 #13
I paid a premium price in my opinion, $8500. So probably not much room for profit. :)
I'd say that wasn't a premium at all, especially up my way for a clean older Ford that looks taken care of. Has adjustable rears too.
/ Bought a Ford 3910 #14
Auxiliary hydraulic pump, deluxe remotes and a steel canopy as well! If you ever want to get rid of it let us know? Heck I'd love to have that canopy for one of mine.
The rears kinda confuse me. It has 15.5x38s on cast center power adjust wheels. I can't find anything that says that tire size was offered on a 3910. 4610, yes.
I agree it was a well equipped tractor when bought new. I'll spend the Winter fixing the little things I find wrong and test it out when Spring comes. I've spent the last couple days building a front grill guard. I'll post a thread when I get it done.
The canopy is actually fiberglass. Not sure how I'm gonna get along with that. I plan to use this tractor a lot in the timber. I built a steel canopy for my Kubota last Spring and get along with it okay. It's tough enough I just let the tree limbs find their way over it. Don't think this one will stand that.
I grew up on Ford tractors. They have a definite personality all their own. I like em. This tractor feels very capable and easy to operate.
/ Bought a Ford 3910 #16
You may as well take that canopy off now and sell it. If you don't you can wait and probably take what's left of it off and throw it away. It won't last in the woods.
I think you are right Rick.
/ Bought a Ford 3910 #18
Ahh, bummer on the canopy, my 3930 2wd has a factory steel canopy, which is great, yours looked similar from a glance. The other 3930 MFWD came with a crap box fiberglass canopy that I removed and gave to a friend, he's still using it surprisingly, but then again he's 70. If I ever come across another factory steel canopy same as mine I'm gonna scoop it up for the 5610. My 5610 2wd has the same power adjust rears as yours with 15.5 x 38s.
RickB has given me some great insight on the Ford's hydraulics, I'm still learning though!
I don't quite understand the rears on this tractor. I haven't tried driving it on solid footing in 4wd to see if it binds. The 9.5x24 fronts are listed as an optional tire for the 3910 but not the 15.5x38s.
What do you think I should ask for that fiberglass canopy on Craigslist?? It's got some chips and dings here and there but is solid.
/ Bought a Ford 3910 #20
I don't quite understand the rears on this tractor. I haven't tried driving it on solid footing in 4wd to see if it binds. The 9.5x24 fronts are listed as an optional tire for the 3910 but not the 15.5x38s. What do you think I should ask for that fiberglass canopy on Craigslist?? It's got some chips and dings here and there but is solid.
I sent you a PM, but just in case, the fronts on my 3930 are 11.2-24 and the rears are 16.9-30. How'd the weight bracket come out?
2015 PETERB/ILT 320 6X4 T/A GARBAGE TRUCK (A66091)
2015 PETERB/ILT...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2019 Ford F-450 Ext. Cab Knapheide Service Truck with Liftgate (A66736)
2019 Ford F-450...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
1 PALLET OF CATALYTIC CONVERTS (A66091)
1 PALLET OF...
