Dodge Cummins Engine Concern
/ Dodge Cummins Engine Concern #202
There was a tree guy in my development last week with two F750 Ford tree trucks. Both had Cummins ISX engines in them LOL
The engine in F650 and F750 is the Cummins ISB. The ISX is a class 8 truck engine.
/ Dodge Cummins Engine Concern #204
DEF, I thought it was diesel exhaust fluid.
I own a early 04 Cummins so who am I to argue, but I will. 2004.5 had a bigger turbo, different injectors, different pistons, 3 injection events instead of two and a few other things I can't remember, but I think the heads were the same.
/ Dodge Cummins Engine Concern #205
/ Dodge Cummins Engine Concern #206
I wish I still had my 04. Didn't have quite as much power as my 07 5.9 but it got a little better mileage.
/ Dodge Cummins Engine Concern #207
DEF I slipped on that one but doesn't matter means the same.
From Pickuptruck.com...
In developing the new “600,” Cummins and Dodge made numerous other improvements or changes to the engine:
• Air inlet redesigned to block hot engine air from entering, reducing the intake charge by 30 to 40 degrees.
• Intake resonator re-engineered for increased airflow
• Larger compressor on Holset turbocharger
• Engine cooling improved with new fan assembly and mounting fan shroud to engine for more efficient airflow through radiator
• Upgraded intercooler
• Upgraded exhaust valves
• Tailpipe increased to 4-inch diameter
• Improved sealing and gasket materials
• Oil-change intervals are now 15,000 miles (vs. 7,500 for competition).
• Holset turbocharger gets bigger compression side
• Switch to electronic control of wastegate
• Upgrades to exhaust manifold
• Revised intake ports in cylinder head
• New piston bowl geometry
• Different spray pattern from injectors
/ Dodge Cummins Engine Concern #208
That's probably correct, 03's and early 04's are known for being more likely to drop valve seats. Didn't know about some of those other changes but some I did. I know the power jumped from 305 to 325, mostly due to the bigger turbo.
/ Dodge Cummins Engine Concern #209
The 04.5+ engines ran a higher exhaust temp because of the third injection event, but the cylinder temps are similar. It was the method used for meeting emissions. I don't buy the claims that some of the engines got better mileage, I had a 97 12 valve (supposedly one of the best fuel mileage cummins) and it got the same or slightly worse mileage as my 97 5.9. I've tracked very tank on both trucks, and I'm happy with the mileage but the 07 beats the old one by a very slight margin.
/ Dodge Cummins Engine Concern #210
/ Dodge Cummins Engine Concern #211
Hello PapaPerk, My Cummins has 92,000 on it. Funny, I too had the rear calipers seize up at around 50k if I remember correctly. The Carter Lift pump is around $125 bucks and very easy to swap out. I keep a spare in the truck tool box just in case, but it's not something to dwell on and I enjoy truck. The Dealer would replace the original lift pump if it failed and locate the new lift pump into the fuel tank. I didn't want them to modify or touch my truck so I kept it original. By the way, the OP should know that you can check the original HOURS on that motor and compare the miles with engine Idle time. It's a Key on/off hold trip A type of check, but the hours are logged in the system module for that engine.
Well my lift pump just failed! Looks like I'll need to track down a replacement! Thank you for advice.
/ Dodge Cummins Engine Concern #212
Really?! Do you live in KY?
Don't have to live there to know some facts....
Here's a map of road salt usage per lane mile annually per state. As you can see, Kentucky uses half as much salt as Tennessee, 6 times less salt than IL, IN, OH. 8 times less that WI, and 23 times less than MI. In fact, KY uses less salt per lane mile than any state east of the Mississippi and north of the Tennessee/North Carolina border with the exception of Delaware. So, yes, Kentucky does not use very much salt on its roads.
:dance1:
/ Dodge Cummins Engine Concern #213
Very interesting map. Pa isn't as high as I thought it would be but I still wish we used way less. I would trade messier roads and needing more driving skill for vehicles that didn't rot out so fast from all the salt.
/ Dodge Cummins Engine Concern #214
What year truck? Any fueling mods? A fass or air dog system is hard to beat but expensive. The new in tank pumps have proven to be very reliable but I'm not sure of the cost. I think it's "Raptor" that makes a pump only that is reasonable and reliable.
/ Dodge Cummins Engine Concern #215
Personally wouldn't get anything from fass again customer service sucked and their "lifetime" warrantee wasn't much better
/ Dodge Cummins Engine Concern #216
I have never owned a fass pump, I have buddies that have them but not me. Fass and air dog are the two big names for people who need much more than stock fuel volume.
/ Dodge Cummins Engine Concern #217
:dance1:
<img src="http://www.tractorbynet.com/forums/files/trailers-transportation/400180-dodge-cummins-engine-concern-roadsaltusagebystate-jpg"/>
That will be a county by county variance. Where I live in KY they use TONS of salt and liquid deicer. The more northern counties use a lot. That's a fact!
/ Dodge Cummins Engine Concern #218
2004.5. 100% stock. Ordered truck and have driven since 1 mile on odo.
I ordered stock fuel pump from Geno's. Should buy me another 80,000 miles. I'll most likely replace pump as preventive maint. Most cost effective, simplistic solution in my opinion.
/ Dodge Cummins Engine Concern #219
The point is, you're arguing that its not a salt problem with Chevys, to a guy that lives in NY, where they use 12X the salt that KY uses, and it affects ALL brands of trucks. :rolleyes:
/ Dodge Cummins Engine Concern #220
All Brands; are you sure???
2023 Chevrolet Silverado 5500HD Auto Crane 6006EH 6,000lb. Crane Mechanics Truck (A64194)
2023 Chevrolet...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
