Front hitch ball mount
/ Front hitch ball mount #1
eppoh
Texas
Iseki TS1610
Occassionally I have a need to use my TS 1610 to move a few trailers around.
I really don't want to disconnect my finish mower, so I thought I might rig up a hitch ball on the front bumper some how.
Before I try to design something, anyone out there already come up with an easy way to do this?
/ Front hitch ball mount #2
My Ford has a mounting hole sticking out from the front bumper that I keep a 2" trailer ball mounted permanently. I'd rather push a trailer around than pull it because I can control it easier through the tight turns in our woods. Looks like some of those 1610 pics I've looked at has a bent flatbar wrap around type bumper on the front that would be easy to weld a plate or flatbar with a pre-drilled hole in it that would fit your trailer ball for moving trailers. May not hold up to a lot of tongue weight, but should move an empty trailer with no problem.
Interesting.
I have only a small mig welder- won't penetrate 1/4 inch steel.
/ Front hitch ball mount #4
Not sure how "small" your welder is?? Is it 220V and/or over 100amp? If so it will certainly weld 1/4". If it's a smaller 110V, it will still do it with the proper preparation. Grind the tab to a chisel point so you have a V to fill. Make the first pass in the deepest section. Then alternate a pass on each side of the growing pile until you've filled the V. You'll be surprised how strong it will be.
/ Front hitch ball mount #5
Do you have a FEL? I purchased a "bolt on" hitch for my FEL for under $100.00. It moves my 7x16 trailer easily when unloaded and have used it once with the trailer loaded with firewood.
I dream of a loader. Don't know if one even exists that will bolt up to a 1610.
Anyway, I am hoping for something that I could just bolt to the front bumper, after drilling a hole maybe.
/ Front hitch ball mount #8
many tractors have a "front weight" bolt holes up in front. to accept a bracket, that holds suit case weights.
many tractors also have a spot were you can remove front "plastic like bumber" to reveal holes for a stronger front grill that goes in front everything. so ya do not inadvertently run a stick or like through the radiator.
both of the above things should be coming directly off the frame.
looking at images i pulled up via google for your tractor, it kinda looks like a U shape bumper that got squashed into a T shape. you might be able to undo some bolts. and pull that off, to slip a better DIY frame up and onto the front. for a receiving hitch.
instead of just welding a ball hitch on and/or a couple nuts in place so you can screw a ball into for different size balls. i would say if ya going to take some extra time, might as well go with a receiving hitch. like back of trucks, so you can change out to different things if wanted. from lower drop hitch, to a straight hitch, to possibly some sort of "mini rack" that folks can buy to hold a couple bicycles or some coolers for camping trip. and just slide that right into the receiver on the front. some folks have went extra step of getting a 12v electrical winch that slides into a receiving hitch.
/ Front hitch ball mount #9
I remember now how I made mine,Atv hitch adapter harbor freight #65961 $14.99 Then welded it to a piece of 2 inch. angle iron and bolted it to the bumper. Works good for mine and is almost flush with the bumper, without the male receiver.
/ Front hitch ball mount #12
Well put the male reciver in, you can stick it out 20 feet if you want to LOL
/ Front hitch ball mount #13
My MF 240D had a steel weight bolted on the front when I bought it. I welded a receiver on the top.
Used a drop hitch mount for trailers.
Or the receiver mount winch.
Lastec 120ER Articulating Turf Mower (A64047)
Lastec 120ER...
New Holland LS180 (A63118)
New Holland LS180...
2004 John Deere 8320 (A63688)
2004 John Deere...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2022 John Deere 5055E (A60462)
2022 John Deere...
