Looking4new
Super Star Member
- Joined
- Apr 8, 2012
- Messages
- 10,747
- Location
- Northern Ontario, Canada
- Tractor
- 2012 Kioti CK27HST w/cab
Get the whole house unit, Luke. You wont be sorry.
A cheap gas generator will run 3600RPM constant. LOUD and uses lots of fuel. If anyone thinks they're going to run a house non-stop for several days with one of these things needs to be aware that they'll consume 1/2 to 1 gallon PER HOUR! So, if your power is out for three days, you're looking at 36-72 gallons of fuel, or, $90 to $210 just for gas! And read the oil change intervals on cheap gens, too. You'll be surprised how often its recommended to change the oil.
Most people run 8-12hrs a day when on a generator. Noise, who cares, the lights are on, the sump pump is running and the freezer is keeping the food frozen. Oil changes are cheap. Going to a 1200rpm or 1800rpm machine will never break even let alone save money for the typical house with an average or 6-12hrs of outages per year. Even a week or 10days won't make any difference.
It's a standby emergency power machine. Why do people think they are setting up a prime power generation unit that will run 24/7 365days a year ?
Because they can do it. They can afford to do it. They want to do it. And its their business. That's why.![]()
Most people here are trying to do something on a budget of less than what the project costs. Hence the 3600 rpm 7200 watt yellow Champion with a GenerLink.com - About GenerLink - The easy way to connect a home generator is a goal for most folk. Good value for the dollar.
The whole house, auto transfer, Auto start Generac or better yet a Kohler or Cummins is the ideal unit.
A generator transfer switch is not a goal for most folks. Its a luxury item that most folks that are frugal realize they do not need.
The easiest and cheapest way to connect a home generator is to put twist-lock connectors on your furnace and well pump and get an extension cord or two, a bag of charcoal and a grill. You'll be warm. You'll be fed. You can flush your toilet. You can cool your beer and maintain your freezer. You can watch your TV. There's no chance of backfeeding. There's little chance of overloading the generator. And you have nice extension cords to do other projects when the end of the world doesn't pan out.
Spending you $$$ on a truck for daily transportation, booze, smokes, 500TV channels, a big screen TV, meals out and a smart phone is just a higher priority than a proper transfer switch. It's called being selfish and not caring about the utility worker or the person with downed power lines in their yard or around their vehicle. Being "poor" is not an excuse to break the law.
even though I could buy the unit at cost , install it myself. No more than my power is out, I just couldn't justify the cost of a auto start stand by genset.. I have a portable generac 5500 w that uses about 5 gallons ? in 8 hrs. I back feed by way of my outside pool breaker box. Able to operate most of the lights, heat, tv, etc . I usually keep about 20-30 gallons of gasoline on hand for grass cutting, etc, so, I usually have plenty of gasoline around for the generator
Charcoal for inside heat claims CO victims every power outage. Sad thing is when it maims or kills children.
Yes you need to protect the line workers. There is little excuse to ever back feed your panel without protection. There are too many ways that an untrained person could connects up the generator "the way they see their significant other do it a dozen times", but miss a step. Use something to prevent deadly errors.
Use extension cords or some type of measure if you don't want to ensure you can accidentally back feed the transformer. But you don't need a multi hundred dollar transfer switch that requires professional installation.
If the point is to protect line workers from death, a manual interlock plate that prevents the main from being connected while the generator is on can be accomplished by a $50 interlock plate.
Thx for the discussion. I just ordered a DuroMax XP10000E, $999 & free shipping. I will use if for powering my shop (welding and lights).
