Oil & Fuel Overfilled Hdy/Trans
/ Overfilled Hdy/Trans #21
/ Overfilled Hdy/Trans #22
plug a hyd. hose in a remote, put the open end in a bucket and pull the remote lever under idle, worked for me.
/ Overfilled Hdy/Trans #23
Turkey baster and a hose.
Don't over-think the problem, just do.
/ Overfilled Hdy/Trans #24
50 quarts when it calls for 48?
Obviously most here would worry, I would not. I'd run it as is. :confused:
I figured if I'm gonna do it, I may as well get it right...anywho, unscrewing the HST filter worked great. I thought it would only drain the filter, but actually It will drain more than that.. Thanks guys!!
/ Overfilled Hdy/Trans #26
:thumbsup: Ditto, actually, I run mine overfilled all the time... mainly because Kubota had a kit to raise the level of oil for the over-riding pto clutch. The kit just changed the sight glass to a dip stick a little higher up...
There's no sight glass on my 2005 L4330. The oil is so clear, with my aging eyes, even with a magnifying glass I didn't get it right. Then I was pulling up hill backwards and I guess the fluid wasn't sufficient at that angle. All's well that ends well.
/ Overfilled Hdy/Trans #28
That is what is nice about this forum, what one person doesn't think of, another person will.
/ Overfilled Hdy/Trans #29
...Then I was pulling up hill backwards and I guess the fluid wasn't sufficient at that angle...
...Fill er up, start pullin, tractor couldn't do it in Mid range, had to get in low range...
I think you were just in the wrong range for pulling the heavy load. The pump will get enough oil to pump even if you are very low (in my case, 2 gallons low). The "extra" volume of oil is for keeping it cool. :2cents:
When I lose power, first I check to see if I left the brake on (which happens all too much) next I check is the range I'm in. I run a lot in High gear - which has zero pulling / pushing power.
My wife, who works right next to me on these pulling jobs, said the same thing... wrong range. I believe your right teg
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2018 Ford Focus (A61574)
2018 Ford Focus...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
