Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #101
Hello Gentlemen, really enjoying the awesome pics!
Which has led to me feeling grapple envy ;-)
I am not looking for a competition, but would some of you care to share the strong points of the different styles of grapples? In a short amount of time I have come across a tremendous amount of information here on TBN. I know different grapples work better for different jobs, curious as to why you all have chosen the grapple style you did?
Thanks!
I chose the L style, because I wanted more depth to the grapple for picking up big rocks, and logs. I think the shorter depth grapples are perhaps better for grubbing out roots and applying more pressure because the teeth are closer to the pivot pins of the loader.
I chose the smaller lighter EA grapple because I was looking for a smaller width grapple, (mine is 50 inches) and light weight to maximize my lift capability yet built with 80,000 psi steel instead of the usual A36 mild steel. As far as I know any grapple is way better than no grapple, but like you said, some grapples are better suited for some jobs than others.
/ Grappling fun - A Picture Thread.... #102
I have an older pin-on bucket vs the newer easy-change bucket so switching between bucket and grapple would be a lot of work. So I got a bolt-on grapple. Even if I had a easy-change system I am not sure I would get a dedicated grapple because a lot of the work I do requires both bucket and grapple. One minute I am moving a rock or stump and the next minute I am moving dirt with the bucket to fill the hole where the rock or stump was. No matter where I am I have both available all the time and even though my grapple is less capable than a dedicated grapple I have always been able to get the job done and don't feel handicapped.
Bucket grapples are great. More folks should consider them if they are doing a variety of tasks. Dedicated grapples are more useful for serious land clearing but a bucket grapple can do just about everything a dedicated grapple can do and it is always mounted.
/ Grappling fun - A Picture Thread.... #103
I finally got mine all hooked up and running. I bought the WR Long OBG2-48 and the third function valve kit from EA. I already have a Kubota pin style QA for the FEL so they made the grapple to fit. Now I can switch out the bucket and grapple in a few minutes. I've been scraping up brush and plowing up dirt to move with the bucket. Today, I had a couple of long trees laying around and tried it out on them. I picked up a tree and cut it in thirds with the chainsaw and stacked the pieces together. Picked them all up and hauled them up the hill to the burn pile. I dumped them and picked up each piece and placed them on the burn pile. My old back feels much better now without having to wrestle those things with the bucket. That Grapple is a great toy, errr, tool.
John
KD4FTA
/ Grappling fun - A Picture Thread.... #105
Hello IslandTractor,
Seeing all these pics I absolutely agree with you, any grapple is better than no grapple! Thanks for the explanation, had not even realized there were clamshell grapples, only buckets. The wealth of knowledge on this site is staggering, and as a new tractor owner, it really makes the learning curve more manageable!
I have a LS XR4046 HST, the bucket lifts around 2,000# at the pins. I am reclaiming an old barn up in Maine to reuse the wood, and so far I have used my pallet forks the most for moving beams and stacks of siding, my lower back keeps thanking me ;-) I also bought the tractor because I do some tree work and as more than one person has mentioned, I am not getting any younger(just better looking, at least that is what I tell myself!). I am looking to start a sideline business with the tractor, doing some land clearing, landscaping work, etc. I am setting it up as a legitimate business, insurance, licenses(has any one from Mass taken the test for the 2A Hoist Operators license?), etc. And thus, I am on the look out for attachments that can make me more marketable and productive.
But as of now, I do not have a specific grapple in mind, and as Poopdeck Pappy proved, I do not even know all the options as of yet. That is the beauty of TBN, the exposure and knowledge you receive here beats what you can get, just by visiting dealers. I also see the advantages of a bolt-on grapple like Gordon's, you get to keep you bucket in action. I have to admit though, the long grapples like K0ua's, JRL305 and Piston's do seem to offer more carrying capacity.... I do have a quick attach on the loader, so switching up front takes less than a minute, even quicker when I have a helper :)
Pappy, have you been able to remove larger stumps with your stump grapple? You said you switched to a backhoe, just for the visibility reasons, or is it just that much better at removing the stumps? How does it work for boulders?
Thanks for all the feedback and keep the awesome pics coming!
Rob
/ Grappling fun - A Picture Thread.... #106
Rob
I don't know the LS XR4046 but it sounds about the same size as my Kioti DK40se which lifts 2700lbs at the pins. I have used that tractor with a light duty 48" open bottom (or L) style grapple with single upper jaw and have been very happy. I've used the combination for seven seasons now mostly doing land clearing that sometimes involves digging out brush and sometimes smaller stumps and carrying trees that I knocked over with a BH ripper. Zero complaints. It has done everything I tried to do. I do not baby it but use it properly. It has some battle scars but is fully functional.
My grapple is a Millonzi but they are no longer available. WRLong, Wildkat, Titan and a number of other manufacturers make a very similar style of 48" grapple. I would look for three things: All the square tubing used in the grapple "frame" needs to be 1/4" wall thickness....a few of the real cheapo grapples are made with 1/8" wall tubing and a few of those have failed at the upper jaw attachment point. I would also personally prefer the tines be 3/8" mild steel (A36). Easier to work on if you ever do need to weld or straighten with heat. Third, I prefer a slight curve in the bottom tines to scoop under roots. That said, one of the nicest new grapple designs is the Everything Attachments light duty ?50 inch grapple which is made with lighter weight high strength steel rather than A36. Most of the grapple is 5/16ths rather than 3/8". If I was buying for any tractor smaller than mine I would get that one but I'm not as comfortable with the 5/16ths. It is probably fine but even EA says it is for 35hp tractors and smaller. I think that is very conservative. I wish they made the exact same design (well maybe with a larger opening) but in 3/8 mild steel (or 3/8 high strength I suppose). If I were buying today I'd agonize over one of the traditional 3/8" open bottom grapples versus the EA 5/16th.
It is hard to break any grapple if you observe a few basic rules: 1) Always lift with the load centered. Reposition if you notice the load is off center as you start to lift. Twist is your enemy. 2) Don't bulldoze with the tines in the ground except a very low speed. You don't know when you will hit a big rock or stump off center, 3) Don't let the open upper jaw be the contact point when pushing, it isn't built for that. A tractor with a 2000lb loader cannot hurt a grapple if those simple rules are followed. You can lift anything the loader will lift without hurting the grapple.
/ Grappling fun - A Picture Thread.... #107
Rob, I have removed some larger cedar trees with it, but it's been done by digging up some of the lateral roots with the stump grapple and then pushing the tree over.
Since I got the little BX23 backhoe, my procedure on larger trees is to use the backhoe to dig up some of the lateral roots, and then I use the grapple on the bigger tractor to push the tree over and then grab the tree and haul it to the tree pile. I have a ripper tooth on the backhoe that rips through the roots without removing a lot of soil. It works great.
As I said earlier, the main issue with the stump grapple is that the solid backplate (where it mounts to the FEL SSQA mounting frame) keeps me from seeing what the front of the grapple is doing. So I have to operate by feel, which is not very efficient. These things were really made to mount to a skid steer where you are sitting MUCH closer to the bucket/grapple and can actually see what it's doing. I'm sure they would work MUCH better in that situation.
Keep in mind that I'm removing cedar trees, which are bulky but don't have a deep root system. They have lateral roots that can run outward from the tree several feet, but they don't go very deep. I sure wouldn't recommend a stump grapple for hardwoods or any kind of tree that had a deep root system that needed to be dug out.
After using my stump grapple and my BX23 backhoe, I think the most efficient tool for digging up trees would be a mid-size mini-excavator with a hydraulic thumb. The huge advantage of a mini-excavator over a backhoe is that it can dig and move, dig and move. A backhoe has to be moved, re-positioned with the outriggers down, flip the seat around, dig, raise the outriggers, flip the seat around, move, etc.
/ Grappling fun - A Picture Thread.... #108
. . . I wish they made the exact same design (well maybe with a larger opening) but in 3/8 mild steel (or 3/8 high strength I suppose). If I were buying today I'd agonize over one of the traditional 3/8" open bottom grapples versus the EA 5/16th.
I couldn't agree more. That's exactly what I'd like to see also.
Oh and FYI, the XR4046 is pretty much the LS equivalent of the Kioti DK45SE or DK50SE. The XR4046 is a really nice tractor and was in my top two final choices when I finally decided on the DK50SE.
/ Grappling fun - A Picture Thread.... #109
Would you buy the same grapple again James? Or would you go with something different? The reason I ask is that I am considering the same grapple for my albino version of your tractor.
/ Grappling fun - A Picture Thread.... #110
Unless something better comes along, I believe I would make the same choice. The only thing I can readily think of that could be better would be a "bigger bite". In other words a larger/taller opening. But I have only run into one rock I couldn't get my mouth around, and I probably could not have lifted it anyway. The 30 inch opening is a lot but 36 would have been better. Of course to make it taller, would have added many lbs of weight and cost.. so like everything in life it is a tradeoff. One very nice feature of this particular grapple is the fact the "teeth" come precisely together. This allows you to pickup very small rocks and roots without getting off of the tractor. Yes I know I am lazy, but I really like this feature. I once remarked to someone I believe I could pickup up a pencil from the ground and put it in a bucket, and while I have never actually done that, I think I could. In any case it is a very cool piece of equipment, and it was instrumental in holding some rather long cedar logs held up against a dirt bank while I got off of the tractor, drilled holes in them and staked them down with rebar. I just could not have done that job by my self without my grapple. The purpose of the logs was to hold mulch behind them to prevent erosion and to hold down the growth of grass.
It has been very usefull in setting rocks in building a rock wall, and I would not want one any wider.
Coupled with a hydrostatic transmission tractor, you can do some very precise movements with a grapple. That is once you get used to using it.:)
/ Grappling fun - A Picture Thread.... #111
Thanks for the good feedback James. It looks like one of the best matches out there for my tractor and general uses.
/ Grappling fun - A Picture Thread.... #112
Thanks!
I use the narrow 44" Gorilla Grapple for the long stuff, after I push them over with it.
And the wide 6', "bigger bite" Loflin Monster Grapple for the short stuff. I had pulled about 30 cedar trees with the tree puller, went back an put on the grapple, picked all of them up in one trip.
This is what dropped out, they are the start of the new burn pile.
/ Grappling fun - A Picture Thread.... #113
I chose a stump grapple because I'm digging out 100's of cedar trees and piling them up. It's very useful as a grapple and somewhat useful for digging up cedars. The reason it's only somewhat useful for digging is that the solid back on it keeps me from seeing the bucket part of it, so I have to dig by "feel".
After I used it for a while, I bought a backhoe to handle more of the digging chores. I still dig some with the stump grapple but use it more for the grapple work and less for the digging work. At a cost of well under $1,000, it was a good investment.
Other than the visibilty how do you like the stump grapple? Is is pretty effective on your tractor at removing trees? I'd kinda like to have a stump bucket.
/ Grappling fun - A Picture Thread.... #114
Roger, I like it pretty well. But, frankly, it works better as a grapple than it does as a stump digger/remover. As I mentioned above, the main problem is that I can't see the toothbar part of the grapple when I'm using it, so I have to operate it mainly by feel. I've thought about cutting some holes in the back plate and covering the holes with expanded metal just so I can see a little bit of what I'm doing.
As I said, it works fine as a grapple. But if I was just gonna buy a grapple, there are other ones I'd buy first. It is handy, however, to be able to dig up some roots, push the tree over and then pick it up and haul it off - all with the stump grapple.
One other thing is that it was less than $700, and is built really strong. So for the money I think it was a good buy. If I was hauling big logs or somesuch, it wouldn't work worth a darn for that. But for hauling brush and cedar trees around, it's plenty good.
/ Grappling fun - A Picture Thread.... #115
I bet the visibility is limited. You could probably see better if it was on a skid steer. I was looking at some stump buckets on ebay last night. I saw some for under $400. I could probably make my own. I was thinking one may be nice for digging out some stumps and trees. I know it won't work on anything that has some size to it. It would also double up as a trenching bucket. I have a tree right now that I have done just about everything I can do with the tractor/ grapple and a ditch witch with a vibratory plow and I can't get it out. $700 was a good price for a stump grapple.
/ Grappling fun - A Picture Thread.... #116
Would there be a way to modify the stump bucket so you could mount a camera to offer better visibility.
/ Grappling fun - A Picture Thread.... #117
I've thought about doing that with my grapple. Trouble is 1) trying to protect the camera and still have it get a view of the tine tips and 2) the small monitors that come with the rear view camera kits really need to be pretty close to your face in order to see detail. That would mean rigging a swing away arm or something like that and increases the complexity of the project. Bottom line for me was that I wasn't willing to put in the time and effort and bucks to set something up without a good sense that it would really be useful. I've managed (with an open back grapple) to do just fine without even though there are definitely times when I'd like to know the exact position of a tine.
/ Grappling fun - A Picture Thread.... #118
I am working on a magnetic mount for front camera that can be moved around depending on what you are doing i.e., bucket, forks, grapple, etc.
Will share once I get it all figured out.
Sent from my iPad using TractorByNet
/ Grappling fun - A Picture Thread.... #119
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A62129)
2014 CATERPILLAR...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63118)
Snap-On Gold Medal...
