JD 24T Versus NH 268 baler
   / JD 24T Versus NH 268 baler #11
Thanks Ken, upside here is most ground fairly flat.......have a small hill in back, maybe 300' up or down, but it would be straight up/down, no side traveling....
If the hill has much slope, these balers can push you into a downhill slide and that could be dangerous. Ken Sweet
Thanks Ken, good point....not much of a hill....appreciate all the input.....though one question is the jd better than the NH if all else equal?
   / JD 24T Versus NH 268 baler #13
They both are good balers. I have personally ran a 268 New Holland and had excellent service from it. In case you need help with the baler when it goes down, I would pick the one that had the best support in your area. Ken Sweet
Makes good sense.....again appreciate all the input and knowledge. Thanks Jack
   / JD 24T Versus NH 268 baler #15
One thing I dislike about JD 24 series balers are the plunger head adjustment bridges with pads(parts keys 15 & 16) that are held on PH with one bolt that have a long history of breaking and the bridge can get lost in the field.
Years back I baled some hay with a JD 214 sq baler pulling it with a JD BO(14 HP). I just dropped hay on the ground IE no hay rack.
E18887 Support - SUPPORT, ADD 186.34 USD 186.34 USD
2 ea - E15459 Pad - PAD, ADD 55.23 USD 110.46 USD
   / JD 24T Versus NH 268 baler #16
While old they are both quality balers; your results will depend on which one has "the big one" first, hopefully neither. I share others concern about a low weight tractor pulling one of these heavy machines. At best you'll get a little seasick from the rocking action the plunger will telegraph all the way up to the operators seat, some of the worst have already been brought up. If I had to do it the deciding factor would be which dealership is closer/better.
   / JD 24T Versus NH 268 baler #17
I agree with Messicks.....I have owned and used a JD24t with MF 35 and a Ford 601 both ran the baler but were on the light side. Both were quality balers in their day circa late 50's ans 60's
txjim, fishheadbob,bucktaker.....thanks all for input....always helps to make best guess what to buy on a budget... thanks Jack
zzvyb6 Thanks for the video...really helps....unfortunately missed out on the NH 268, but still checkin the JD24T Appears about same size so just might work. Again Thanks Jack
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
