My new XR4040HC
/ My new XR4040HC #1
sdinsley
Hollywood, Maryland
LS XR 4040HC
image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgwell here are a few pics.
/ My new XR4040HC #3
Tractor looks GREAT. Be sure to check the tire pressure. Dealers like to over inflate for various reasons, but very common to be over inflated. ;)
/ My new XR4040HC #4
Congrats & Welcome, I'm very happy with mine so far!
/ My new XR4040HC #5
Nice looking tractor! I actually hadn't given LS a thought, but after seeing yours I checked out their site and like what I see. I'm a big fan of Shibaura engines and two-pedal hydros, and I see LS has both. 12.5 front tires are a huge plus. I'm gonna have to go sit in one and see how the joystick and 3pt controls feel.
/ My new XR4040HC #6
How do you lower pressure with loaded tires?
/ My new XR4040HC #7
Well, they should not be filled above the valve stem with it at the top-12 o'clock position. Just let some air out. ;)
My question would be, why were they ever over inflated at all? :confused2:
/ My new XR4040HC #8
As you posted"The Dealers like to do that" If I let the air out I will also let the fluid out too. Any other idears?
/ My new XR4040HC #9
Is your little New Holland getting "worn out?"
/ My new XR4040HC #10
I prefer to think of it as well worn...like a good pair of cowboy boots. :D I do realize that it won't last forever so I'm checking other options out.
I don't know what I'll end up getting, but I can guarantee it won't be a Mahindra. They have the worst loader stick ergonomics I've seen since the 70's. My NH dealer carries them instead of rebranded LS tractors. I love my dealer...but not that much.
/ My new XR4040HC #11
Put the stems at 12 and let the fluid out, they are over filled and should not really be that full according to everything that I have read. Other than that, ya got what ya got. :mur:
/ My new XR4040HC #12
What Mahindra's are you looking at? :confused: The joysticks are by far not all in the same location model-model. A 3550 HST would be a good model for you I would think. They are showing a cab version in the specs now also. :cool:
Nothing against the TYM Mahindra's, but I would not get one. If I was to go that way, I would just get a TYM model. My guess is that these are what you have looked at. :confused3:
/ My new XR4040HC #13
Are the TYM's the 5110 series?
My mistake. I meant the 5010 or 6010.
/ My new XR4040HC #14
Yes, all the 10 series tractors are built by TYM for Mahindra. Wrong series of machines to be looking at IMO. :no: These were the only cab tractors that Mahindra had for quite awhile and they carried the open station equivalents. I feel that they are the economy models now, as they are no where near as nice as the TYM equivalents.
Are you considering something in the 40hp range, or are you going to step up one size? HST, power shuttle, shuttle transmission. The 3550 is available in HST or power shuttle. They are actually a pretty nice machine. Seems like you would like an HST model of that size. ;)
/ My new XR4040HC #15
Well, that explains that then.
When I finally do pull the trigger I'll step up to a 45-50hp, cab and HST. Joystick and 3pt control layout as well as vision to the BB will be the most important things I look at first. I'd like a stronger loader as well as more lift height for loading trucks with less of a ramp. What I really need is a 3/4 scale 210LE with a cab...that doesn't exist...or a modernized 545D...that doesn't exist.
/ My new XR4040HC #16
When I finally do pull the trigger I'll step up to a 45-50hp, cab and HST. Joystick and 3pt control layout as well as vision to the BB will be the most important things I look at first. I'd like a stronger loader as well as more lift height for loading trucks with less of a ramp. What I really need is a 3/4 scale 210LE with a cab...that doesn't exist...or a modernized 545D...that doesn't exist. Something around 10-11,000 lbs would b ideal.
/ My new XR4040HC #17
Very nice looking LS, congratulations.
As a side note, I would go with LS over rebranded LS (NH) any day
/ My new XR4040HC #18
This sort of goes along with the same thing with the TYM tractors vs the TYM built Mahindra tractors. Seems like it is simply best to get the tractor from the Manufacturing company. Get more features-options for less money. :confused2:
/ My new XR4040HC #19
Maybe...but it all comes down to the quality of the dealer (for me anyway.) My NH/Mahindra dealership is 30 minutes away, has ten really good mechanics and a very knowledgeable service manager that knows my situation, and will talk me through things on the phone to save $ and downtime. He has mentioned that if I did purchase an LS that they would work on it, but can't put me ahead of their own brands if their shop is busy. Now that I'm better informed, (thanks Brian) I may have to revisit the Mahindra option. I did like the beefy 3pt design when I looked at them.
That LS sure looks good though. Maybe I'm just partial to blue. :confused3:
/ My new XR4040HC #20
I know that I am. Didn't stop me from buying red though.;)
skeleton / rock bucket (A56857)
skeleton / rock...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2018 Caterpillar 308E2 CR Excavator (A61166)
2018 Caterpillar...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
