Shear Bolts
/ Shear Bolts #1
treefarmerguy
Kubota 5030
I can't find shear bolts for a Puma 74 inch rear mount snow blower. Owner's manual calls for a Grade #2 for the auger. Can I use a regular grad#2 bolt of the same size? The drive shaft calls for a M6 x 40mm bolt with no grade# indicated. Any suggestions appreciated.
/ Shear Bolts #2
Yes, you can use any grade 2 bolt of the same size. Check your local Tractor Supply Store or whatever hardware store near you that carries M6 x 40mm bolts. A standard bolt is a different diameter and if substituted will cause it to shear prematurely. Buy extras when you get them.
/ Shear Bolts #3
Metric equivalent to an SAE Grade 2 is a 4.8.
Metric fastener strengths are named property Class and not grade. Even so, the Property Classes are roughly equivalent to the SAE Grade system. The following provides some examples.
Metric Grades
Property Class*****************SAE Grade
4.6****************************Grade 1
4.8****************************Grade 1
4.8****************************Grade 2
8.8****************************Grade 5
9.8**************************9% Stronger
10.9***************************Grade 8
11.9***************************NONE
12.9***************************ASTM A574
The easiest way to tell a metric fastener Property Classis by looking at the fastener for a numeric designation. These decimal numbers will be marked on the hex head or on the top or side of a socket head fastener.
/ Shear Bolts #4
The auger drive uses a common grade 2 bolt as the shear bolt. No relief cuts or fracture points, just a regular hardware store bolt with no marks on the head. The PTO drive shearbolt s a 6x40MM 8.8 hardness. That is a typical good quality metric bolt and will be marked 8.8 on the head. Just about any source of metric hardware will have that size in 8.8 hardness.
New Holland TS6030 (A64119)
New Holland TS6030...
JOHN DEERE 5403 TRACTOR (A64280)
JOHN DEERE 5403...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
