Can you edit your posts any more?
/ Can you edit your posts any more? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
I'm a chronic misspeller, that no matter how many times I read before posting, I never fail to see a typo until after I post. Recently when I click to edit, I can get "in" to edit my text, but see no way (button?) to save the changes. There's a box that asks "Reason", so I type "typo", enter, page renews but my old typo post is still there? Is this the same for everyone?
Is this on my end (my computer need new java update or some such) or is the website?
/ Can you edit your posts any more? #2
I don't know - I'll try.
Editing my post.
/ Can you edit your posts any more? #3
No problem editing my typos.
Bruce
Editing this message. Right under the box with the message is a button that says "Save Changes."
I don't see anywhere a place to give a reason for the edit.
/ Can you edit your posts any more? #4
It worked for me. Down under the text section I edited, the button was still there to save.
Bruce
I know what you're talking about, as I use to have that. But now there is no "Save Changes" button.
I also can't post pictures anymore. After "browsing" I hit the upload files button and nothing happens.
Hmmm?? :confused3:
/ Can you edit your posts any more? #6
You shouldn't have to edit your posts for misspellings typos, the text should be underlined in red and if you right click on the original text BEFORE posting you can correct then.
/ Can you edit your posts any more? #7
You only have about two minutes to do it before you're exposed to the world permanently.
/ Can you edit your posts any more? #8
You can edit your posts for 24 hours after you post them.
As for the missing save button, if using IE, turn on Compatibility Mode and that should fix it.
Aaron Z
/ Can you edit your posts any more? #9
Aaron Z
Yep, turning this feature on fixed mine
/ Can you edit your posts any more? #10
It's the web site. I have been having a problem now for some time. I have sent e-mails, no joy. I can edit if I use a Ipad. Another problem I have also is when I post something I have to sign out and then back in to see the post. It appears to be going thru a "Third Party", reviewed and then okayed for posting.
I am also getting yellow triangles with a tractor outline scattered across the web page.
/ Can you edit your posts any more? #11
/ Can you edit your posts any more? #12
What browser are you using? If you are using IE, turn on compatibility mode.
Here is what I see in IE 11 with Compatibility Mode off:
Here is what I see in IE 11 with Compatibility Mode on:
Aaron Z
/ Can you edit your posts any more? #13
Aaron Z
Do as he says. I'm not having any problems after turning compatibility view on. This is the 1 st. computer I've to do this on ,and I have always used IE.
/ Can you edit your posts any more? #15
Let's think about this for a few seconds.
There are 100s, if not 1,000s, of posts daily.
There isn't a panel of people reviewing every post then okaying for posting.
/ Can you edit your posts any more? #16
/ Can you edit your posts any more? #17
I had that problem... didn't know about the 'compatibility mode' trick so I simply switched to Firefox. Works fine, so is pretty clearly an IE issue. Simply one of many over the years.
/ Can you edit your posts any more? #18
CM, what browser are you using? I haven't seen this feature.
/ Can you edit your posts any more? #20
Finnish your posts with "aw so anglish not verrry nice good slow sloory"
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A63569)
2019 GALYEAN...
25FT FLATBED DOVETAIL TRAILER (A63569)
25FT FLATBED...
Duo Lift Sprayer Trailer (A64047)
Duo Lift Sprayer...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
