Farm King Snow blower
/ Farm King Snow blower #1
batwing
MI
TYM T353
Back in 1995 I bought a used 61/2 ft. Farm King snow blower, it has been a good blower but I need some bearings and should change the gears.
hopefully some one can tell me a good place to get the gears and find out the model number.
/ Farm King Snow blower #2
Farm King and Allied are owned by Buhler now, but one of these manuals should work.403 Forbidden
I would guess they are North American sourced gearboxes and bearings.
Thank you for the information, I took the numbers off the bearings (made in Japan) and found some on Amazon. They are getting hard to find and not cheap but when I get it back together it should be as good as new.
Ron
/ Farm King Snow blower #4
Ron
All bearings are metric, so no worries there,
you need to write down all the information that was punched in the
bearing races or the bearing ID tags on the housings
you can obtain your bearings at Kaman industrial supply.
The gears can be bought there too most likely as they are for a specific
chain size and you should plan on getting new chain there as well
You need to take the old chain with you to make sure the give you the
right one as there is a difference between the standard duty chain and
the heavy duty chain rated H.
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
Trek (A65640)
Trek (A65640)
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
2022 EZ-GO ELITE...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
