L45 Accessory Power?
/ L45 Accessory Power? #1
avc8130
Northern, NJ
Kubota L45
Does anyone know if the L45 has a factory aux power connector somewhere? I need to add some power for a solenoid valve. My original plan was to setup a relay off the battery, but then I thought maybe Kubota left a present for me somewhere.
ac
/ L45 Accessory Power? #2
Well - - my aux power connection comes off the fuse block. Its located just under the hood, passengers side, very near the steering wheel. The fuse block was an easy find - the aux power wire, not so much. This wire ran up under the hood and was mixed with a bundle of other wires. Persistence paid off.
Was there a fuse in the fuse box labeled "aux" or something?
Is this powered with the key on?
ac
/ L45 Accessory Power? #4
The cover of the fuse box has a diagram of all the fuses on the inside. There is one labeled Aux Power - 15A. Aux power goes on/off with the main tractor ignition key. Yes, Aux Power is on when the tractor key is turned on.
Perfect! I need to go exploring.
ac
/ L45 Accessory Power? #6
I was looking to wire up a back up light on my B3200. I notice a factory wire taped up at the back of the tractor and its a switched source. Not a real heavy gauge but runs a 30 watt work light nicely. Often the factory will have extra wiring if you did not purchase all the options.
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2000 Bobcat 763 (A64126)
2000 Bobcat 763...
40ft Shipping Container (A64194)
40ft Shipping...
2022 EZ-GO ELITE...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
