Touch'e
but
the fact that there ARE failures of major brands shows they break to.
and it does seem that some of the small Jinmas that were based on the 200 series platform that were later modified up to around 30 hp have seen more breakage than most,
but as greg g pointed out on ( tractor point )
As far as 4wd and the loader, the problem is a comparatively weak front axle on the Jinma 200 series. I say comparatively, because there are other Chinese tractors that you can use the loader and 4wd - that have a far far lower failure rate.
Anyway. Many Jinma 200 series owners have complained that they were denied warranty coverage for such failures, citing owner abuse. Honest and forthright dealers warn 200 series buyers up front of the potential for problems if/when using the loader in 4wd.
i think it should be taken into account that these are some of the least expensive 4x4 tractors available..
An active thread right now that shows major brand tractor makers have had substandard parts? design? of front axle components
B2910 front wheel snapped off thread)...
i found this enlightening
My front loft wheel on my
B2910 snapped of while clipping my field. It was a low-stress operation on the tractor. I found that it sheared from the axle on a poorly engineered and executed weld. The axle consists of a flange (to attach to the wheel) and a shaft, welded together and machined afterward to be the finished axle. The weld penetration on the inside was completely machined through, and the weld penetration on the outside was machined back to be less than .050" thickness. There was about .400" of interface with no weld penetration. This .050 of weld is what failed. The replacement axle was similarly fabricated, but at a larger diameter interface, with no obvious indication that the weld on the inside had been machined through. That indicates to me that the manufacturer became aware of this faulty design and took corrective measures for the new part. If this is true, I believe that the factory should have issued a recall and replaced them all for free. This could potentially be a very dangerous situation.
,,,,Thank you for the lucidity in describing this latent defect.
Chinese tractors are or at least- were- considerably less expensive than name brand machines.
There is no completely free lunch,
most buyers of chinese machines Know they will be doing the repairs themselves, and are ok with that.
I would be much more irritated buying a New or almost new and (expensive) name brand machine and then having problems that were not covered by a warranty or recall-
