Reminder - Cost of Ownership of Gas vs Diesel
   / Reminder - Cost of Ownership of Gas vs Diesel #41
Does a truck that is going to tow run 87 octane or does it need to run mid-grade or high test to really work? Where I live mid-grade and diesel are the same price. My little Toyota with a knock sensor did not like to tow unless it had 92 octane.
My 2003 Jetta diesel has had zero expenses different from a gas model until I had to replace a $1,100 fuel distributor. 410,000 miles when I did that swap. I wonder what else will mess up the next 400,000 miles. I get 47-50 mpg. With a gas engine I would have gotten at most 35 mpg. If one were considering apples to apples in the 2003 VW the 1.8T cost the same as the 1.9 TDI. The 2.0 was about $2,000 less. Back in 2003 diesel was less expensive than gas.
12 mpg gas and 18 mpg diesel. Where I live today $2.80 per gallon low test gas, $3.39 per gallon diesel. Drive 800 miles a week and the gas model uses $186 in fuel. Diesel uses $150. Only $36 savings times 52 weeks. Only $1872 a year in savings with the diesel. Factor in a few oil changes which could be $60 each more expensive for a diesel so you only save $1692 per year with diesel. Of course I go back to the question of can you run low test and actually pull a 6,000 pound trailer with a lot of air drag on low test? I have no idea. Now if you are paying a $10,000 premium for diesel engine then you will have a hard time justifying. Neighbor got a 1 ton dually Chevy 4 door, 4wd, long wheelbase work truck with a diesel for less than $50,000. I can't recall what the price was but it was a lot less than the pimped out 3/4 ton diesels you see at ag shows. If you run a vehicle with a diesel might save $18,000 in fuel but you paid a $9-11,000 premium. Of course it also assumes that you drive a fair bit a year. If you only drive 10,000 miles a year a diesel might be a horrible purchase.
So that bit of math begs the question of why not drive a 30 mpg car if your truck is not going to work? I hate driving my Dodge diesel that sucks fuel at 16-20 mpg depending on if I tow a trailer, haul hay or make it work somehow or not versus the VW which gets 46-50+ mpg.
If the injectors in my Dodge do not mess up (which could happen in a Hemi I guess) what costs more to maintain for a diesel? One battery versus two is a $160 expense every 7-10 years. Spark plug change every 100,000 miles on a gas engine. My Jetta diesel maintenance seems to not be any more than a gas model.
   / Reminder - Cost of Ownership of Gas vs Diesel #42
I run a Buick for that reason, but after registration and insurance, not sure if I save that much money.
   / Reminder - Cost of Ownership of Gas vs Diesel #43
DP, I got on the internet and looked up fuel price in your area of Indiana. I got 2.69 for regular gas, 3.42 for diesel. That's not $1.07, that's more like $0.73. In my area it more like $0.64 today.
Here is the link I used to come up with those prices. Indiana Gas Prices - Find Cheap Gas Prices in Indiana, IN
Up here in Northern Indiana, in South Bend, regular gas is between $2.78 and $3.00 while diesel is between $3.55 and $3.99. So, between $0.77 to $1.21 higher for diesel.
   / Reminder - Cost of Ownership of Gas vs Diesel #44
DP, I ran the numbers, if the gas truck gets 12 mpg and the diesel gets 18 mpg, it's fuel cost is less. For 1000 miles and using the fuel prices I found in your area $2.69 for gas, $3.41 for diesel, the diesel uses $190 and the gas truck uses $224 in fuel. In a lot of areas the difference would be greater, diesel and gas are a little closer in price in my area
   / Reminder - Cost of Ownership of Gas vs Diesel #45
With the numbers I posted above for today's prices here and the 12mpg and 18mpg that are being bantered about, the diesel gets 33% better mileage. But diesel fuel costs between 22% and 30% more (again, based on where I am located at today's posted prices). Thats a fuel cost savings of at best about 11% and at worst, only about 3%. Factor in the $6000 dollar option and you have to drive many, many miles to justify the purchase based on fuel savings alone.
   / Reminder - Cost of Ownership of Gas vs Diesel #46
I "topped off" with gasoline this morning in Missouri @ $2.619
Same place was selling #2 diesel @ $3.429
I know you probably will not believe me but for some reason in my area they always report "EXEMPT" prices on diesel. I use the Gas Buddy App and when I get to the station it's always $.35 more per gallon or so.
I posted a pic just for this very reason because Gas Buddy was right on for 87 but way off for diesel.
Chris
   / Reminder - Cost of Ownership of Gas vs Diesel #47
You're going to use 8333 gallons of gas to drive 100,000 miles at 12mpg.
You're going to use 5555 gallons of diesel to drive 100,000 miles at 18mpg.
You'll spend $23,165.00 on gas and $19,720 on diesel at $2.67 and $3.55 respectively
and
You'll spend $24,999.00 on gas and $22,164 on diesel at $3.00 and $3.99 respectively.
That's a difference of between $3445 and $2835.
You'd have to drive at least 200,000 miles just to pay for the cost of the diesel engine option.
   / Reminder - Cost of Ownership of Gas vs Diesel #48
Buy me on road diesel at that price 15 miles from my house and I will pay you the difference. I run both gas and diesel equipment so I'm not a diesel hater. Today the best I could do was the price I quoted.
Diesel made sense for me in 98 when I got my first one. Thing started to sway in the mid 2000's when I bought my last one. Back then the gas jobs were not what they are today and diesel fuel was cheaper than gas.
Chris
   / Reminder - Cost of Ownership of Gas vs Diesel #49
$6000 option? I wish. It's double that on a new truck.
Chris
   / Reminder - Cost of Ownership of Gas vs Diesel #50
In my area the price difference was about $0.53 per gallon. DP, I don't doubt your numbers.
The main point I'm trying to make is people keep throwing around numbers to prove a point, they throw out opinions, but the truth is they don't have a clue what they are talking about. They haven't kept exact records and run the numbers.
DP you said you kept track of every dime you have put in your vehicles. You have hundreds of thousands of miles on these vehicles. Let's ignore the initial cost and the resale value. Just maintance and fuel cost. What is the cost per mile of these. My guess is you can't or won't crunch the numbers, it's a lot of work. I admit I don't have the numbers.
There is a guy on the Cummins forum that has close to 1,000,000 miles on his truck. He is a hot shotter. He has kept track of every expense on his truck, every drop of fuel. He got over 900,000 miles out of his original engine without a rebuild. He averaged well over 200,000 miles on injectors. This guy knows exactly how much his truck has cost per mile.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 367...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Freightliner M2 106 AWD Terex Commander 4047 Digger Derrick Truck (A55973)
2015 Freightliner...
16' WAGON FOR HAY TIRE ROAD STYLE (A52708)
16' WAGON FOR HAY...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
