3-Point Hitch Easy way to store your Auger
/ Easy way to store your Auger #1
azkubotaguy
Prescott Valley, AZ
Kubota L4060
Making changes from gannon to auger to brush hog is a pain in the rear. I finished doing a job digging a bunch of post holes and needed to put my gannon back on, so I go to take off my auger and thought of a great way to store it and make it easy to put it back on by myself, I will let the picture do the talking :laughing:
/ Easy way to store your Auger #2
If you don't mind the auger rusting in the ground and having to lift the hitch to get attached again, it's quick and easy that's for sure. I think that most people prefer to have them hanging some where. ;)
/ Easy way to store your Auger #3
I did that when I first got my auger, but went to hanging it once I saw all the rust on it and figured that was a big part of why the cutting teeth got dull faster then I think they should have.
Eddie
/ Easy way to store your Auger #4
really, it's a great idea in spite of rust. hadn't thought of it. to me, the safest way to mount one is with 2 people. i don't have that luxury, but still hang mine in a tree & have a solo method of mounting that seems to work. but still like your idea if it doesn't sit too long.
/ Easy way to store your Auger #5
I like hanging better too, but if one wanted to store "sort of" in the ground, drive in 3 lengths of pipe, 120* apart, to hold the auger vertical and put a brick or board for the tip to sit on to keep it off the ground.
bumper
/ Easy way to store your Auger #6
This is what I built for my phd.
Back under....lift boom....connect phd boom to the swing boom....disconnect from tractor....swing boom under roof. It balances very well and 1 person can connect/disconnect in under 5 mins.
/ Easy way to store your Auger #7
I did that when I first got my auger, but went to hanging it once I saw all the rust on it and figured that was a big part of why the cutting teeth got dull faster then I think they should have. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/397118-easy-way-store-your-auger-post-hole-digger-stand-june"/> Eddie
Eddie;
Like your idea. Where did you get the turnbuckle with loop and hook?
Thanks!
Sent from my iPad using TractorByNet
/ Easy way to store your Auger #8
I just picked it up at the hardware store. It doesn't really work very well because the hook on the turnbuckle doesn't fit into the piece of metal to hand the post hole digger from. I've added a short length of chain to that piece of metal and now it's perfect.
Eddie
/ Easy way to store your Auger #9
Thanks Eddie;
At previous ranch I cemented two 4x4's in ground and had a removable 4x4 cross piece that set on top of the verticals in a couple of galvanized brackets. I could back in, raise the PHD, insert the horizontal piece, the lower the PHD. New PHD has smaller clearance between the boom and the drive shaft so, old idea no longer works.
Lots of great ideas here.
I have a business so none of my implements sit too long, I don't have the luxury of someone always being available to help swap out things, so this was a quick idea. The nice part is it will attach quicker when I need it again.
/ Easy way to store your Auger #11
I want to build a nice, custom storage rack for mine one of these days. But for now, I just hang it from a suitable tree branch with a tie-down strap.
xtn
/ Easy way to store your Auger #12
Eddie
Being aware of how well you construct everything...did you cannibalize one of your screen doors for that turnbuckle?
/ Easy way to store your Auger #13
That is a good system in the desert but not in my neck of the world. You pull that out of the ground here in Pa. and you will have a rusty mess.
/ Easy way to store your Auger #14
I did the same thing and had to get my neighbor's tractor and chain it to the top of the auger to get it out while I lifted it with the 3pt. The soil around here is damp and heavy, it's like concrete after awhile. Also I can't turn the auger backward, so there's no way to unscrew it. If it were on a skid steer it would be easier.
/ Easy way to store your Auger #15
I heard about one guy who got his auger stuck that-a-way and never could get it out. That auger just kept working it's way deeper. Now the distance to the center of the earth is 3959 miles, and near's we can tell that dang auger is down there somewhere. You've been warned.
/ Easy way to store your Auger #16
Doesn't look like there much water in them parts to rust much of anything.
/ Easy way to store your Auger #17
There's moisture every where, but as he said, he uses his stuff and lot, so it's not in the ground for long. I believe that there are better ways to store the PHD that have it in the open(not in the ground) and would be waaaaaay easier to hook up. He has to lift the hitch to get it up to the draft arms, that right there is enough reason to not store it in that manor IMO.
Just my :2cents:
/ Easy way to store your Auger #18
Soon as I get my tractor - equipment shed built I am going to hang mine from a piece of barn door track. Roll it out away from the wall to hook up and back to the wall for storage.
/ Easy way to store your Auger #19
I put an eye bolt/screw in a tree limb (that was stout enough to hold the auger) and a short length of chain with a snap clevis. Beeen hanging it that way for 15 years now.... The limb has grown a bit grew over the eye screw, no biggie....
But then we have trees up here in Michigan.......
/ Easy way to store your Auger #20
I like that idea too, may have to look into doing something like that myself.
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
10" Utility Blower Fan (A66408)
10" Utility Blower...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
