3-Point Hitch Easy way to store your Auger
   / Easy way to store your Auger #11
I want to build a nice, custom storage rack for mine one of these days. But for now, I just hang it from a suitable tree branch with a tie-down strap.
xtn
   / Easy way to store your Auger #12
I did that when I first got my auger, but went to hanging it once I saw all the rust on it and figured that was a big part of why the cutting teeth got dull faster then I think they should have.
Eddie
Being aware of how well you construct everything...did you cannibalize one of your screen doors for that turnbuckle?
   / Easy way to store your Auger #13
That is a good system in the desert but not in my neck of the world. You pull that out of the ground here in Pa. and you will have a rusty mess.
   / Easy way to store your Auger #14
I did the same thing and had to get my neighbor's tractor and chain it to the top of the auger to get it out while I lifted it with the 3pt. The soil around here is damp and heavy, it's like concrete after awhile. Also I can't turn the auger backward, so there's no way to unscrew it. If it were on a skid steer it would be easier.
   / Easy way to store your Auger #15
I heard about one guy who got his auger stuck that-a-way and never could get it out. That auger just kept working it's way deeper. Now the distance to the center of the earth is 3959 miles, and near's we can tell that dang auger is down there somewhere. You've been warned.
   / Easy way to store your Auger #16
If you don't mind the auger rusting in the ground and having to lift the hitch to get attached again, it's quick and easy that's for sure. I think that most people prefer to have them hanging some where. ;)
Doesn't look like there much water in them parts to rust much of anything.
   / Easy way to store your Auger #17
There's moisture every where, but as he said, he uses his stuff and lot, so it's not in the ground for long. I believe that there are better ways to store the PHD that have it in the open(not in the ground) and would be waaaaaay easier to hook up. He has to lift the hitch to get it up to the draft arms, that right there is enough reason to not store it in that manor IMO.
Just my :2cents:
   / Easy way to store your Auger #18
Soon as I get my tractor - equipment shed built I am going to hang mine from a piece of barn door track. Roll it out away from the wall to hook up and back to the wall for storage.
   / Easy way to store your Auger #19
I put an eye bolt/screw in a tree limb (that was stout enough to hold the auger) and a short length of chain with a snap clevis. Beeen hanging it that way for 15 years now.... The limb has grown a bit grew over the eye screw, no biggie....
But then we have trees up here in Michigan.......
   / Easy way to store your Auger #20
I like that idea too, may have to look into doing something like that myself.
2020 BOBCAT E32 EXCAVATOR (A52707)
2020 BOBCAT E32...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A57024)
2020 Westfield MKX...
2010 KMC 3376 Peanut Combine (A57024)
2010 KMC 3376...
LMC Quick Attach Hay Spear (A56469)
LMC Quick Attach...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
