Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #291
I Posted it on you tube and the link is here. The secret is out fellas!!! Yes, it doesn't take days on end to do what I did đź’Ą
   / Cutting / Groving / Siping R-4 for snow #292
Wow that was actually pretty dang fast ... I'm assuming that you were holding the camera with I've hand and grooving with the free hand ... Would it have been even faster with using both hands?
   / Cutting / Groving / Siping R-4 for snow #294
Yes, pretty easy and fast.
Yup, even speeds up when I use TWO hands....
That is the correct tool but I purchased mine from EBAY. I think it was around $60 bucks shipped.
It came with a dozen blades. I am still in my first blade and I have yet to plug it in.
   / Cutting / Groving / Siping R-4 for snow #297
This is the same tool mentioned in post #11 in this thread almost 4 years ago.
My apologies... I admit I didn't read all 292 posts before me! :ashamed:
   / Cutting / Groving / Siping R-4 for snow #298
The only reason I mentioned it was in case someone thought there was a different tool involved.
   / Cutting / Groving / Siping R-4 for snow #300
Back around post#244 I put pictures up and told of my snow plowing with cut tires. After using the tractor around the yard this summer, I wan't to let everyone know of the possible side effects of cut tires in mud and gravel. First if you operate in mud, the cuts will fill with mud and then if you then go down the driveway fast you will leave strips of mud flying that look like the rubber strips you cut out of the tires. Also left alot of mud strips in the garage when you go to use the tractor the next time. Second in the gravel areas I drive thru the cuts always seem to collect small stones in the cuts, again not a big deal until you go road speed and the little rocks come flying out. Not trying to knock cutting tires just reporting back on my experience with the cut tires is all.
2017 Ford E-450 LP Handicapped Bus (A53422)
2017 Ford E-450 LP...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2008 Ford F-450 Crew Cab Service Truck (A55973)
2008 Ford F-450...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
